Question about Symantec WinFax Pro 10.0 for PC
No dial tone
We recently purchased this software. Install was easy. We have a KSU box for our telephone line meaning we have to "pick" a line to make an outgoing call.
Is this the cause of our no dial tone. How do I fix this problem?
  • BRFB Mar 19, 2008
    Yes through our local phone company.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    you on DSL by chance?
  • 143 Answers
Dialing and Location in WinFax Setup.
Set your prefix. If you have to dial 9, set it here.
If you have different "lines" to pick from, then you can setup "Locations", which allow different setups for each location you create. Troubleshooting WInFax at http://www.getfaxing.com
Posted on May 29, 2009
By picking a line, do you mean you have to dial a "prefix" or a code when the phone is picked up?
if so, then you can set this in the Dialing & Location setup in WinFax under prefix.
http://www.getfaxing.com for more winfax info
Posted on Apr 24, 2008
    Genius:
  • 3,587 Answers
And does your line to your computer have one of the filters installed going to your modem line?
check your computers warranty here 4 FREE
Posted on Mar 19, 2008
All 4 hand units say "line in use" How do exit tis situation? hand units model KX-TGA410, baseunit KX-TGA131
A "Line in Use" message generally means that there is no dial tone detected. Assuming that all of the handsets are in Standby and any other phones are connected to that line are also on their hooks, then you need to determine why the base isn't getting a dial tone. This can be an inside or outside wiring problem.
I like to use an old wired telephone for testing since power isn't required to use the phone. You also need another RJ-11 telephone wire. Try connecting a new RJ-11 wire between the KX-TGA131 base and the phone jack. If there is a dial tone with the new cable, you had a bad cable. If not, try the alternate phone. If the test phone has a dial tone, then the KX-TGA131 has failed or has a power problem. If the phone is under warranty, contact Panasonic.
If neither phone has a dial tone, take your test phone to another jack connected to the same phone line (number), if available. If you have a dial tone here, then the problem is in the first jack or the wiring to the jack. You can try to repair the jack yourself. Remove the cover plate and look at the jack. If any wires are loose, reconnect them to their appropriate location. See http://www.lanshack.com/wire_phone_jack.aspx for the usual patterns. There are two types of telephone jacks, keystone and screw terminals. For the keystone type, you need a punch-down tool (available at many hardware stores in the electrical section) to put the wires back in place. Do not strip the individual conductors before using the punch down tool. For screw terminals, strip the wire before securing it under the screw.
If you do not have another jack or there is no dial tone at the second jack, find the incoming telephone service box. Open the box and check the wiring. If you find an RJ-11 jack, plug in your test phone and listen for a dial tone. If there is a dial tone, you have a wiring problem. Check the jacks as above. You may want to have someone else check the wiring in the walls if there are no broken/loose wires in the jacks. Your telephone company will usually offer the service for a fee.
If you can't test the phone line at the service box or there is no dial tone at the service box, contact your telephone company. They will test the service box and should repair outside issues for free. (Some providers are trying to avoid copper repairs.)
If you have DSL, you may need to check the line filter. This filter can disrupt the dial tone when it fails. If the filter is in the interior, you are responsible for the replacement. In my service area, the DSL filter was in the service box so my telephone company repaired it.
I hope this helps.
(I've had no line issues several times. Sometimes, it was the result of a contractor cutting through underground lines. With copper wire, rodents sometimes damaged those underground wires. Once it was simply an issue of a contractor who'd left one wire loose after upgrading the service.)
Aug 26, 2017 | Lands Phones
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
My phone says "Line in use" but nobody is using it.
Some of my telephones will read "Line In Use" when the phone doesn't detect a dial tone. I like to use an old wired telephone to check whether the problem is with the cordless phone base or the phone line wiring.
First plug in the test phone and check for a dial tone. If there is no dial tone, try a different RJ-11 cable between the phone and the jack. If there is still no dial tone, use the test phone at another jack and check for a dial tone. If you have two jacks with no dial tone, find your incoming telephone service box. If you have a relatively new phone service installation, the service box will have RJ-11 jacks. Plug your test phone into the jack and check for a dial tone. If there is still no dial tone, contact your telephone company. They will repair an outside wiring problem for free. If the service box doesn't have an RJ-11 jack, you'll need to ask your telephone company to test the phone line for you.
If there is a dial tone at another jack or at the service box, you have an inside wiring problem. You can check for loose or broken wires inside of the jack. Most use either screw terminals or a punch-down design. For the screw terminals, strip another section of the unbroken part of the wire, if needed. Secure the wire under the screw. For the punch-down terminal, take off the cover. Then you'll need a tool that is available in most hardware stores in the electrical wiring section. Do not strip the wire; just place it over the correct place in the terminal and push it into the contacts with the tool. Trim off any excess wire with a small pair of small wire cutting pliers, if the excess wire is blocking the cover from fitting back onto the terminal. http://www.lanshack.com/wire_phone_jack.aspx has a good diagram of the wire color and pin assignments. If the wiring is okay at the jack, you'll need to check the rest of the wiring for problems. Since the broken wire might be inside the wall, you may want to have a professional check it out. Your telephone provider's technicians can do this for a fee. If you have a DSL computer line, you should check the DSL filter. If the filter is inside at the jack, you'll need to replace the filter. If it is out at the service box, your telephone company will do the replacement.
If there is a dial tone at the jack with the test phone, check the purchase date on the L401 system. If it is under warranty (1 year usually), contact Motorola. Otherwise, replace your Motorola phone system. It's generally not worth the minimum repair and shipping costs.
I hope this helps.
(I've had dial tone issues after lightning strikes (the DSL filter was damaged), mice eating wires (buried phone line) and due to county road crew/contractors who dug too close to the wire. The first two problems required phone calls to get a technician to fix the outside line. The last one gets fixed by the contractors/phone company as soon as they can.)
Nov 09, 2015 | Motorola L401 DECT 6.0 Digital Cordless...
How do I change pulse to tone dialing?
Are you sure about the phone model number?
Tone/pulse is set in the common equipment (KSU) configuration, not the individual set.
Press Feature 9*80 to see the system software version.
Jan 27, 2015 | NorStar M7324 Telephone
I have 824 installed at my office, with three CO lines. All CO lines were working OK, but one out of them can not be selected now, and any body dialling from outside to that number gets a busy tone. In...
If the CO line works properly when disconnected from your system KSU, something in the KSU is keeping that line off-hook. If the trouble isn't caused by a phone that's holding the line, try resetting the KSU by shutting it off and unplugging it from the AC line. Reconnect the power and turn the system back on. This should clear up the problem if it was due to the controller being confused, which can sometimes happen. If the system picks the line again and holds it, check the phones for one with a stuck line select button. Then you'll need to have the KSU serviced if the trouble continues.
Apr 03, 2011 | Panasonic KX-TA824PK Phone
I have use llinksys PAP2T togather with Panasonic KX-T7730c. does it possible?
Gather what? A PAP2T is a 2-port FXS box. A 7730 is a phone that works on a Panasonic Key Service Unit. You can plug the CO lines of a KSU into the PAP box and the 7730 into the KSU and get dial tone on whatever line you used on the PAP if that's what you're asking.
Carl
Mar 24, 2011 | Panasonic KX-T7730 Corded Phone
ATD 66419700 NO DIAL TONE.
That means that the modem cannot detect the correct (or any) dial tone when it picks up the line. Connect a normal; telephone to the line and lift the receiver. If you hear a normal dial tone, then the line is ok. Ithat is the case, then the modem may be faulty. You could try atz command and see what happens. If it is on a pabx or fax machine or something, the dial tone may be non-standard and teh modem won't recognise it. In that case, consult the modem manual for the AT command that tells it to ignore dial tone and dial anyway. You may have to enter that command as well as teh correct command to store that setting, alternatively you can enter the commands as an initialisation string in whatever software you are using to dial.
Hope that helps.
Oct 26, 2010 | D-Link DFM 562E (dfm-562e) Modem
Fax machine wont send or reiceve
Check to see if you have a dial tone. If not, plug a regular home phone into the jack in the wall and see if you can call it or dial out. You might have a dead phone line.
Apr 22, 2008 | Office Equipment & Supplies
Norstar m7310 phone
Rushy: I assume you have a KSU which controls the entire system. The KSU is cabled to each line number provided by your local phone company. Once you have this line established it now makes contact with your phone set via dedicated cabling to each telephone set.. With all this hardware in place you can now program the line keys on each set for either one touch dialing or line access for your dial tone. Program guides can be aquired through GOOGLE by entering " Norstar m7310 program guide".Thank You. Jerry
Feb 08, 2008 | NorStar Meridian M7310 Phone
Symantec WinFax Pro 10.0 for PC Logo
301 people viewed this question
Top Symantec Computers & Internet Experts
Lisa
Lisa
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
