It will not light manually as the ignition probe is electronically controlled. If it doesn't stay lit normally then it will more then likely not stay lit when trying to light manually.
you may have a defective control board, - presuming you replaced the defective one. the on/off light should respond if you turn it on or off - but the auto/gas light should not show that both AC and gas are powering the refrigerator. Contact Dometic for a new control board, and, if that doesn't fix the problem, you need a new refrigerator.
The pilot sequence is designed to run for 45 seconds. It could be that the thermocouple is not triggering the cycle once the pilot is lit. I am having the same problem and intend to replace the thermocouple and then give it another go. The fridge works fine on electric but stopped working on gas last week.
Hi: In my travel trailer I find it is easier to light my Dometic if I bleed the lines by starting my stove top. It uses a lot more gas to get lit and floods the lines with propane. Your fridge uses such a small amount of gas it takes a long time to bleed the line to it. Don't focus on just the oven.... run any propane appliance on the way to it first. I hope this helps, Jeff
Here is a link to parts service and PDF of this model. If yours is a propane model then you may need to contact the numbers on the PDF If you need to download Adobe go to adobe.com and dowload the free adobe 10
