Question about Brother MFC 210C All-In-One InkJet Printer
Print only in black
I want to set to print only black .how do i do it without empty color inks
  • 832 Answers
You have two choices to do that:
1. If you want to print in color sometimes in future again, do this:
Buy some glycerin alc. (drugstore) and some destilled water.
Mix 2 ml glycerin alc (or glycerol) with 8ml of destilled water and refill the ORIGINAL C/Y/M carts with the mix. (Drill a 2mm hole onto the top into the brandname).
The mixture prevents the color side of the ph from drying out.
2. If you dont want to print in color anymore:
stick some black adhesive tape around the "nose" of each cart.
The nose is the small window which hides a small black flag that signals the printer that the cart is in position and that there is enough ink within.
Posted on Mar 19, 2008
SOURCE:
SOURCE: Epson C66 won't print without color cartidges
I have the exact same problem with my epson RX420 printer.
When my color cartridges were running low, i went into the settings and changed it to 'print only in black and white' - a number of weeks passed and somehow the color carts came up as empty, althought i never printed anything in color.
Epson is a complete rip off.. I now have a printer with a full black ink cartridge and cant print anything until i replace the color ones (COSTING €50!!!! )which i have no use for>
My Advice to anyone =DO NOT BUY EPSON PRODUCTS/EQUIPMENT/PRINTERS.
This sort of treatment of customers/users is just evil
Posted on Nov 16, 2007
micromaster
  • 3614 Answers
SOURCE: Can you set default to print using only black ink?
Color problems stem from your print cartridge or from your printer settings. Obviously, as a cartridge runs out of ink, colors will fade or disappear. Nozzles can also clog. Most printers include software utilities (including one for cleaning nozzles) that let you clean and align cartridges and print heads. You can usually access these utilities from an Advanced or manufacturer-specific tab in the printer’s Properties dialog box. Run both utilities several times if necessary.
If you’re sure the cartridge isn’t to blame, make sure you have updated drivers and the correct paper type for your job. Next, check the print quality and paper type settings in your printer Properties dialog box and in your application’s print settings. Printing Draft quality jobs can often result in strange color output. Your printer’s configuration utilities may also have color management controls. Find them either as part of your printer’s Properties dialog box (click the Color or Advanced tabs) or in a separate application installed as part of the printer setup process. Use these to adjust Tone, Brightness, Levels, and other settings.
Posted on Mar 08, 2008
  • 125 Answers
SOURCE: ink cartridges
Go through your standard print procedure. File>print then look for the properties button which is usually on the top right of the window. Press Properties and look for either Printing in B/W or grey scale. That should prevent your color cartridges from printing. After you check that box, you should be able to print black only.
Posted on Aug 19, 2008
  • 2985 Answers
SOURCE: How to print with black ink only when color is empty
Correct - the same for most InkJets- Full complement of cartridges
re uired -- Many years ago some basic Z series Lexmarks had colour/black swappable casrtridges- but that is long gone.
Posted on Aug 30, 2008
  • 163 Answers
SOURCE: I just want to print a word document in black ink, but...........
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. ( Also Epson gets to sell you more cartridges)
Posted on Apr 03, 2009
Will the canon mg5320 print only black with out other color cartridges installed
The manufacturers removed the option long time ago due to the printheads and muzzles which get screwed up while printing with one or more empty cartridges. here are some explanations and tutorials on how to actually print with an empty cartridge:
How to print without black ink
Jan 12, 2016 | Canon PIXMA MG5320 All-in-One Printer
I don't have black ink is there a way to print with just using yellow, cyan, and magenta
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why your Brother printer won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Jan 05, 2011 | Brother MFC255CW All-in-One InkJet Printer
One colour cartdridge is empty can i print black only
To print with black ink only, you have to go Print, on the window that shows up click on Preferences then select the Color tab and tick the check-box for Print in Greyscale.
But bear in mind that ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you print with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
Dec 23, 2010 | HP Photosmart D7160 InkJet Printer
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Aug 22, 2009 | Canon PIXMA MP210 InkJet Printer
Print WITHOUT colour cartridge
If you right click the printer in the Printers section of the control panel and select printer preferences, there should be a tab called maintenance. In this tab, you should find a setting called Ink Cartridge Settings. Once you click on this setting, click black cartridge only. This should allow the printer to only use the black ink and therefore you won't need color.
If you have any other questions or this doesn't solve your issue, let me know.
Jan 10, 2009 | Canon MX300 Office All-In-One Printer
Won't print with only 1 cartridge empty
sorry you can print unless all your cartridge are having some ink
Dec 17, 2008 | Epson Stylus Color 740 InkJet Printer
PRINTING WITH BLACK INK CARTRIDGE ONLY; COLORED CARTRIDGE IS EMPTY.
Apparently, if you hold the "resume button" (the one next to the power button) for about five seconds after you get the message saying to replace the color ink cartridge the machine starts printing. I did this after I went to "maintenance" under "preferences" and changed ink to "black only." At first that alone did not work, but after trying the resume button for 5 secs it worked okay.
Sep 13, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Print black w/o color ink cartridges loaded
No, in general all current inkjet printers require the installation of a color cartridge even if you want only black printing.
(If you had an old cartridge "Empty", you might be able to purchase a resetter (Epson) and set you printer to print in black only.)
You can, set up your computer to print in black only by selecting Mono printout in your print set-up.
There are a few Canon printers (Older) that used to print in Black or Color only printing....but no longer available......
Feb 09, 2008 | Office Equipment & Supplies
epson printers won't really print if one cartridge is not detected or detected as empty. the only option that i can suggest to you is that, buy a continous ink kit at any ink refilling station in your place. i highly recommend that dont leave a cartridge empty with ink cause it might clog your printhead. using a continous ink system's cartridge is auto reset, whenever the printer says that the cartridge is empty, it will automatically resets itself. ink refill kit comes with 100+ml of ink per color i think. and it is much cheaper using original epson ink.
Sep 26, 2007 | Epson Stylus C66 Inkjet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
310 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
