Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore 16602 dishwasher
I need to replace the heating element.
How?
Thanks,
Karyn
  • 1 more comment
  • Anonymous Nov 11, 2008
    My dishwasher is less than 2 years old. The heating elemen is split in two parts. Can I replace the element myself
  • mjhawaii May 11, 2010
    Yes, how do you send it through a diagnostic test?
  • robert samples May 11, 2010
    why do you feel you need to replace the heating element is it burned into
How do you send it through a diagnostictest
Posted on Oct 25, 2008
    Problem Solver:
  • 19 Answers
Exactly, if the heater is not defective, please do not replace it. I am aware that the owners manual says that if you have the clean light to flash then the heating element may be defective. More times than not the heating element is not defective but the controls can be reset and you can send the unit through a diagnostic test to find out what may be defective.
Posted on Jun 10, 2008
Model #66516352301 replace heating element
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 06, 2011 | Kenmore Dishwashers
Green clean light wont stop blinking unable to use dishwasher . It is an energy saver. the drain button works ..and when you push start the light comes on but will not run for cleaning
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 19, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
Washer is running for 3-4 hours -- way too long.
No machine should have a 3 hour wash cycle. The timer will not advance if the water is not up to the proper temp. A severely extended wash cycle is usually caused by a faulty heating element.
I assume the water supply line was hooked up to the HOT water and not the cold. And you run the sink until hot water is present in the line.
The next time you run this machine, allow it to operate for a few minutes, then open it up and see if a ball of steam escapes. No steam = no heat = no timer movement.
If this is the case, the resistance of the element will need to be checked with a multitester set to ohms. A faulty reading will be zero or overlimit or infinity and the element will have to be replaced.
It may also be as simple as a broken or disconnected heating element wire. Good luck
Dec 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher not cleaning dishes as good as before. is there a filter that needs cleaned or changed somewhere?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
8750rtyjdt
Nov 02, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Smart wash not working
MOTOR IS SEIZED UP NEED TO REPLACE THE MOTOR
May 29, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher not draining water all the way
heatman101
kkjl
Feb 03, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
"Lock on" light keeps flashing - cannot run dishwasher
same issue..
Other boards suggested heating element issue - but nothing very clear or compelte.
Aug 10, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher will not start
turn unit off at the breaker and leave off for 10 mins before turning back on,  if this does not reset the unit, then your control board is probably bad or the heating element could be going bad.  call a repair man for service
Apr 22, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 587
You may try the rubber gaskets and fasteners that attach your heat element through the bottom of the dishwasher body. This is the only full penetration of the shell involving metal that I see. You could see these fasteners if you remove the dishwasher from its current position, rotate it clockwise on its side and see the two cheapo pressed metal nuts on threaded studs that have wires attached. These keep that black metal loop on the bottom (inside the washer) in place. Remove wires, unthread pressed metal fasteners, check heater element for the rust issue (replace if needed) and reinstall new rubber gaskets and fasteners. Hope that helps!
Oct 09, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
145 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
