Question about White Sewing 1632 Mechanical Sewing Machine
Bobbin problem THe thread keeps on wrapping around the bobbin case or else it just knots on the underside of the fabric and either way the maching jams and stops and I have to cut the fabric free. I have tried everything that the instruction booklet recommends but there is nothing specific regarding this problem
  • livin4christ Jun 18, 2008
    The thread keeps on wrapping around the bobbin case and/or it
    knots on the underside of the fabric and the machine jams
    Please email me with the timing instructions.
    Thanks,
    JoAnn
  • 3 Answers
When you thread your bobbin and put it in the case the thread should be on the left side of that little arm on the bobbin case. It allows the thread to slide off that arm.
Another issue could be your lower tension. You may need to loosen or tighten it.
I had the same issue and the above two things eliminated the problem.
Posted on Aug 30, 2009
SOURCE:
Necchi 575FA how to put the bobbin spool in the case?Bobbin mats up with a lot of threads on the bottom stich.
The problem most likely is not the bobbin. The problem is the top thread. If thread is knotting, tangling under the fabric, it is a top thread problem.
Remove the top thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning.
If there are still thread clumps under the fabric, you will need to increase the top tension. (The extra thread appearing under the fabric is excess top thread hanging up under the fabric.) You may need to keep adjusting the top tension until both top & bobbin threads meet in the middle of the fabric.
Mar 11, 2018 | Necchi Sewing Machines
I have juki 1541industrial machine . It started sewing upside down . Instead of nice stiching on top show side it on bottom. Any ideas
This is caused by the tension between the bobbin and needle threads being out of balance. If the knots between the stitches are on the bottom side, then you need to tighten your needle thread tension a little at a time until the knot is in middle of fabric. The reverse of this is if the knots are on the top, then either your bobbin tension is too loose or your needle thread tension is too tight. If this occurs, then loosen your needle thread a little at a time to see if knot goes down in middle of fabric. If it does not, then you need to increase the tension on your bobbin thread. This done by taking bobbin case out and tighten the small screw located in the middle of the spring on the side of the case. You only need a slight, steady pull on the bobbin thread - the more you put on the bobbin, the more you are going to have to put on the needle thread.
Feb 13, 2015 | Juki Sewing Machines
Cant get my bobbin in right position it keeps knotting up on inside of fabric
Top thread problem, Not enough tension on top=loops on the bottom of the fabric; too little tension on the bottom = loops on top of the fabric. Yes, I know it seems backwards. See: http://www.picturetrail.com/sfx/album/view/22521551
Dollars to donut holes, you either threaded the top of the machine with the presser foot down (it has to be UP to let the thread into the top tension), or you're trying to sew with the presser foot still up (which is an issue common to people trying to sew bulky seams).
Take the thread off the top of the machine, take out the bobbin case and give the machine a cleaning, rethread the machine, fetch up the bobbin thread and hold the bobbin and top thread ends together under and behind the presser foot for the first 2-3 stitches of each seam.
Jan 26, 2014 | Brother LS-2125 Mechanical Sewing Machine
My stitch does not sew on right side of fabric. I sew & see the underside of the stitch. I remove the fabric & the stitch is on the underside.... Never known sewing machine to do this. Help!!
Hi. first thing is to remove the threads from the machine, top thread and the bobbin, and replace to manufactures instructions. If still the same the problem sounds as if there is no tension on the bobbin [under] thread, adjust to a light tension. Then adjust top thread tension until the knot is in the middle of the cloth. Most times people keep tightening the top tension..
Aug 10, 2013 | Brother XL-2600I
Needle thread knots up under fabric.
I have the same problem but i have not watched it. I does not seem that anyone wants to help us here, I am going to other sites until i find someone knowledgeable. apparently we are the smartest here at the moment ;)
Mar 31, 2013 | Sewing Machines
Upper thread gets jammed in bobbin area
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 12, 2012 | Brother Sewing Machines
Bobbin Thread is "birdnesting"
Get out the manual and refer to the maintenance section for cleaning the machine.
Especially the bobbin area. You want to make sure the area around the bobbin case is free of lint and thread.
Use a new bobbin and re-thread the machine, with the presser foot UP.
Install a new needle, again according to the directions in the manual. Installed incorrectly can lead to mis-stitching.
If the problem persits, the timing may need adjusting.
This should be done by the sewing machine tech for Kenmore.
Sewusa.com has a guide for this in the repair section, but you could end up with more problems.
Apr 29, 2010 | Kenmore 15202 Mechanical Sewing Machine
Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Mar 16, 2009 | Sewing Machines
Bobbin continues to pose problem - knotting thread underside of fabric,
In 99% of all problems with "bird's nesting" or "knotting" it is an issue of the thread coming out of the take up lever (at threading guide #3) (from the spool; through the first thread guide at #1 down to #2 and up to # 3) when the thread comes out of the take up lever, the machine can not regulate the thread and it floods the machien with thread and wraps itself around the bobbin case. OR! Your tension is too loose. Raise it. Your machine should preform perfect at tension #4 unless you are using speciality threads or fabrics.
ALWAYS be in the habit of threading your machine with presser foot up so that while threading between paths 1 and 2 you are certain to have the thread pass throught the tension disks.
This will happen on a $50.00 machine or a $5,000 machine. The thread needs to be regulated.
USE GOOD THREAD!
Thanks,
Bonnie
Oct 25, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
White Sewing 1632 Mechanical Sewing Machine Logo
289 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
