Question about Baby Lock Eclipse Serger
What does the differential feed do?
I have my MIL's Eclipse serger and am wondering what the purpose of the differential feed is. I have read through the manual, though I find it very confusing, pictures and text don't match up on the correct page. It really is just a sloppy photocopy.
thanks.
    Problem Solver:
  • 4 Answers
Get a basic book on serging from your library. The higher the #, the feed dogs infront feed fabric in faster, keeping knits, etc from stretching. It can also gather if you go to the highest #. A slightly lower # the N can be used for slippery fabrics because it slows the front feed dogs, but be careful because it can stretch and ruin the fabric. I have only once needed the lower # for a really slippery chiffon. Start on scraps and experiemnt. It's not used very often unless you sew daily or professionally.
Posted on Apr 12, 2008
SOURCE:
What is the difference between a baby lock sx elcipse special edition serger and sx eclipse serger?
# of threads and # of different stitch types?
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 24, 2014 | Baby Lock Eclipse Serger
I have a Babylock Eclipse serger..while sewing with it the machine jammed up and I cant get it to sew. It sounds like its stuck or motor is jammed..I just hear a small hum when I press the pedal.
A serger does not have a bobbin,they use loopers instead to form a chain stitch. I'm very familiar with the baby lock and they are a simple machine. Email me and I will try to guide you to the solution, chances are it not an adjustment problem but a dry feed cam. my email is [email protected]
Jan 25, 2014 | Baby Lock Eclipse Serger
Need to know what the dials are supposed to be set at. the post that the needles won't go up and down as it jams at some point
Tension dials factory setting is all at 5, stitch lenth on about 2 or 2.5 and differential on zero.
Sep 27, 2011 | Baby Lock Eclipse Serger
I need to know how to oil a simplicity serger-easy lock-with differential feed
I have a Simplicity serger SL880 that was my mothers. She past away about 8 years ago. I was trying to use it but appears the motor may be locked up that moves the feed dogs. Is there a place to oil it? If so where? Thank you.
Apr 18, 2011 | Simplicity Serge Pro SW432 Mechanical...
How do I operate the differential feed? I bought
The differential feed is usually on the right side, you will see a some numbers. Their should be one that sticks out (might be red, The letter "N", "0", or a line) This is the normal setting. A larger number is going to gather the fabric and a smaller (.99 and below) is going to stretch.
Hope that helps :)
Chris
Jun 06, 2010 | Sewing Machines
How do you thread the Singer QuantumLock 5 Differential Feed?
www.singerco.com/pdf/14SH654_threading.pdf
Its a different model, but most sergers thread the same way.
Mar 30, 2009 | Singer Sewing Machines
I have a baby lock imagine machine. I'm sewing with streatch velvet, and the stitches are off the fabric, or the loopers are too loose. I tried tighting the looper thread fine tuning screw, adjusting the...
Stretch fabric is made for using the differential feed on your machine, sergers love stretchy things. Try widening the stitch you are using and turn your differential feed down one notch to allow the machine to get a good grip on the fabric, you may need to bump the differential feed up more if it still doesn't stitch nice, keep trying on a piece of scrap fabric of the same as you are using until you are happy with the stitch.Another solution is to put some lightweight tissue paper under the seams and then tear it off after you have sewn the seams, this works but will dull your blades over time.
Oct 30, 2008 | Baby Lock Eclipse Serger
Baby Lock Protege BL5370Ed Serger
I was in a similar position (but had the manual). The manual isn't as complete as I'd like. Anyway, what finally got mine working were the following:
1. turn all tensions to zero before putting thread through them
2. thread the upper looper, then lower looper, then needles.
3. when threading the lower looper (mine kept pulling out), after passing the thread through the looper eye, it needs to go pretty much straight up, not wrapping around anything else - other thread, for example. Mine was at one point trying to wrap itself around a post.
4.when everything is all threaded up, make sure all threads are under the foot *and* pulled to the left (even though the manual says pull to the back). Then chain off without fabric, turning the handwheel by hand to make sure loops are forming. If so, adjust tensions to where you think they should be (mine are currently all between 2 and 5), and add fabric. Then tweak as needed.
For me, this was a lot of trial & error, hair-pulling, and getting tips 1, 2, and 4. I figured out #3 on my own, with much swearing along the way. Good luck!
LF
Sep 24, 2007 | Baby Lock Eclipse Serger
Sewing Machines Logo
302 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Thomas F. Schneider
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
