Question about XFX NVIDIA GeForce FX5200 Graphic Card
Plumbing leak under sink. how to fix...how do you get to it. HELP Peggy
  • 2 more comments
  • chrispugh Dec 21, 2008
    my kitchen sink leaks. The pipe which connects to the drain at the bottom of the sink has come loose and is just sitting loosely up against the bottom of the drain. How do I reattach the pipe to the bottom of the drain in the kitchen sink.
  • Anonymous May 11, 2010
    Have you got that leak fixed yet?
  • albert getty
    albert getty May 11, 2010
    where is it leaking from a tap or abs a joint in copper or threaded bolt
  • Marc Hess
    Marc Hess May 11, 2010
    Can you tell me more about the leak, try to locate the source of the leak. Always look for the highest location that you can find the moisture.
  • 103 Answers
Pipe wrenches. and access should be gained through the cabinet doors beneath the sink. it prolly is your p-trap just go get a new one and make sure it is the same material and color as the old one is.
Posted on Aug 15, 2009
SOURCE:
Price Pfister Marielle, 26 series, leaks around the top of the spout body when water is turned on. How do I take it apart and fix the leak?
1 under the sink turn off both water supplies
2 disconnect the supply lines at the on/off valve EZer than at faucet
3 under sink unscrew the retaining nut(s)
4 on top wiggle or pry the faucet and lift up and remove.
5 know you can replace the spout and don't forget the new O ring that's why it leaks anyway. you really just need the new washer O ring .
6 Reinstall check for leaks
7 caulk around faucet.
Hope this helps Mike
May 31, 2018 | Price Pfister Plumbing
How do I fix a very slow leak under sink where pvc meets brass
Hi there, there is two things you can do here, one is to buy a little roll of plumbers tape, you can buy this at any hardware store, or you can apply some wax around the leak, using a candle, collecting the dripped wax and applying it around the leak. I hope this helps you. Good luck
May 03, 2018 | Plumbing
How do I find where the leak is in my RV sink and how to fix it?
Could be drain, trap or connections at faucet underneath sink. Best get in cupboard with light, turn on 1 faucet at a time & check very closely. Time and patience
Jan 31, 2018 | Plumbing
MY SINK IS DRIPPING LEAKING UNDERNEITH THE KITCHEN SINK
Probable plumbing failure. Locate the source of the leak to determine what has to be done to fix it.
Jan 25, 2014 | Home
Leak at spout pivot point on Kohler K-378 traditional kitchen fau
Not going to stop the leak by tightening. Go to local plumbing or home store and they make a repair kit that has the pieces to fix your problem. Also has a diagram on the back of the kit to guide you, its really an easy fix, shut off water under the sink, both hot and cold,and just remove the handle and unscrewing the top of the valve assembly. Good luck dont forget to rate.
Mar 30, 2009 | Plumbing
Maytag Quiet Series 200 Dishwasher Leaking Internally
two possible sources of water
either
inlet valve leaking. turn water off after use and if no water accumulates, then cause is leaking valve
or
if drain is plumbed in to a spigot on the sink trap, then every time you empty water from the sink, some of it goes down to the washer
cure by taking the drain hose up as far as possible under the sink in a swan neck
Oct 12, 2008 | Maytag Dishwashers
Drainage problem
Sounds like you're getting back-flow from your sink where the dishwasher drain line is plugged into. You have to make sure the DW drain hose has a vacuum break in it. Sounds hard, but it's not. Look under the sink. See where the DW drain hose plugs into your plumbing (probably at the disposal)? If it angles downward and into the cabinet to your DW, that's the problem. It's siphoning water out of your sink (along with the chopped up food from the disposal) and into your DW. The fix for this is simple. Remove the drain hose from the plumbing under the sink. Then form an upside down "U" with the drain hose and firmly attach it to a stationary object under there (I always use the water supply plumbing to the faucet for this...) using whatever you have, good duct tape, wire ties, etc. Then reconnect the end of the hose back to the plumbing and you're done! Job time= < 15 minutes.
Aug 13, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
XFX NVIDIA GeForce FX5200 Graphic Card Logo
56 people viewed this question
Top XFX Computers & Internet Experts
Ekse
Thomas F. Schneider
1400Slugg
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
