Question about Hobart H600 Stand Mixer
H-600 Turn Handle slips, bowl does not go back down
Turned the handle like always and now the bowl does not go back down, handle turns with some noise
  • hickorydec Mar 25, 2008
    After removing panel, the top bar support had broken off the housing of unit and cracked the unit itself. Possibly looking into welding instead of having to replace. Let me know if anyone else has run into this problem
  • 640 Answers
Does the handle seem to move easier?there is a shear pin on the handle and if it breaks the bowl wont move.Another thing to check is remove the silver plateon the front of the mixer there are 2 possibly 4 screws,when you remove this plate you will see a long screw about 3 feet long.turn the handle if the screw doesnt turn that pin may be broken.let me know.
Posted on Mar 20, 2008
  • anthony james
    anthony james Mar 25, 2008
    If what your talking about is a brass square nut its a hobart part # and so is the plate thats on top.
HOW DO I MANUALLY LOWER BOWL IF MIXER WILL NOT START?
Trina you might be better off to contact Hobart or an authorised Hobart service agent about this. The lack of answers probably indicates resident hobart experts are absent.
May 06, 2015 | Hobart 140 qt Mixer Model V-1401 Used Mint...
RESET A HOBART 140 QT MIXER
The V-1401 has a power bowl lift that is belt driven by the same motor that is used to mix. Remove top cover to check the belt. If belt is good and not slipping, is the operator handle working on /in the bowl lift gear box? If not, could be broken shear pin on handle or worn out parts in gear box. Next thing to check is the output shaft of the bowl lift gear box. If it is turning when the operator handle is engaged and the bowl lift jack shaft is not turning there is a broken shear pin between the output shaft and jack shaft. If everything is good to this point the bowl lift yoke has a large brass nut on back side of it that the jack shaft goes through. If the nut is worn the bowl lift yoke will slip, fall and/or jam. to unstick and lower the bowl , one can turn the jack shaft by hand. WARNNING : if the nut is worn enough the yoke can drop suddenly and it is very heavy.
How do i adjust the bowl height on an ksmc5os?
I'm not familiar with your model but on stand mixers with crank handle bowl lift there are 2 places for it to be. With bowl lift down there can be s screw straight in from the front on the pedestal just above the bowl lift sliding bracket, the full range of adjustment is half a turn, anti clockwise to raise, clockwise to lower. The other one is a small screw sticking down from under the gear case where the bracket that carries trhe bowl slides up and down. Clockwise to lower, anti clockwise to raise.
Aug 19, 2014 | KitchenAid KSMC50S Commercial Stand Mixer
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
Bowl can't be lifted
I think if you look at the bracket that rises as you turn the bowl, you will see that it is supposed to "tighten up" as it lifts against the stationary "rail" that is part of the column. If it is too tight to go up all the way, see if a little candle wax or a a dop of light machine oil applied to the "rail" will overcome the excess tightness.
Jul 05, 2009 | KitchenAid KP2671 Professional 6 Series...
Can't get the screw adjustment to change the height of the bowl
I had a similar problem with mine - the problem turned out to be that I hadn't clicked the bowl into place corectly. If you find the bowl is tilting forward slightly then you probably need to push it into the clip at the back.
May 17, 2009 | KitchenAid KP26M1X Stand Mixer
Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
May 13, 2009 | Hobart H600 Stand Mixer
Hobart H600 bowl wheel slips
Some of the older H600s do not have a bowl lift lock. Look to page 18, items 57-72.
http://www.hobartlink.com/Extranet/ExtranetManualsAndCatalogs.nsf/6E1A88214EC64B59852568E1006A99F9/$File/F18797%20Rev%20B_lk.pdf
Take off the cover and see if the assembly is there. If not, get a bungee cord for the handle. If it is, when you start the mixer the solenoid should fire and lock the gears in place.
If the assembly is there and not working, check the it is not binding. If it is, free the assembly up and check the solenoid. If it was frozen it usually causes the solenoid to overheat and burn out. Good luck - Mike
May 08, 2008 | Food Mixers
Hobart H600 Stand Mixer Logo
194 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
