Question about Riso RZ220 Duplicator
Timing is off on the duplicator
I was wondering if there is anyone who can give help on fixing the risograph
with the timing problem?
  • canufixit Mar 18, 2008
    The machine would make the plate and the margin of the copy would be off by 0.75''.
    What can I do to solve this problem?
  • 552 Answers
Http://www.teachertube.com/view_video.php?viewkey=b45096ff04c04038fff5
https://us.riso.com/portal/page?_pageid=777,1&_dad=portal&_schema=PORTAL
Two great links for your machine.
One of them is a video demo and the other is the us riso website.
Posted on Mar 18, 2008
    Genius:
  • 3,587 Answers
Do you have a service or user manual on this yet? we can get one, methinks
6ya staff
SOURCE:
A risograph 3770 doesn't print when I say 'test print' and says there is a jam
Maybe it is just some dust at the sensor in the exit path! Clean the sensor in the small hole between the exit belts with a brush ...
Aug 23, 2012 | Riso RZ220 Duplicator
Error message - system error T02-405 how can i fix this
T02-401 and T02-405 is the elevator motor (paper tray up movement) is binding in some way.
Sep 22, 2010 | Riso Office Equipment & Supplies
Risograph RA4050 diplaying error code E11, anyone know what that means? Has recently been putting masters on the drum crooked and making grinding noise.
E11 is the pressure control motor encoder has nothing to do with the master problem it is most likely out of time. (grinding noise)
May 03, 2010 | Riso RZ220 Duplicator
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
ERROR D17-237(CAN'T DETECT MASTER) THIS ERROR IS ON A RISOGRAPH RZ 390, PLEASE HELP?
Hi
The RF tag on the master roll in not detected. try getting an oem ( original) master roll
these rolls are chiped
Jan 17, 2009 | Riso RZ220 Duplicator
Duplicates
It sounds like you don't clear the stick after taking the pictures. Try re-formatting the stick through the camera menu.
Oct 23, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Code d--13, ---9 risograph rz220
Check out copytechnet.com. Its a free service that covers copiers only. You can get in touch with a Risograph technician to give you the answer.
Oct 08, 2008 | Office Equipment & Supplies
Risograph Drum
Try run a hundred copies at slow speed and full density/ pressure.
If that fails get a can of WD40 and spray it under the master, then rub the area with your finger. this will desolve the dryed ink on the drum surface.
Dermot
Sep 09, 2008 | Riso RZ220 Duplicator
Risograph 5800 repair
This is a cutter moter lock. you would have to replace the cutter unit.
Nov 10, 2007 | Office Equipment & Supplies
207 people viewed this question
Top Riso Office Equipment & Supplies Experts
Runepic
Runepic
Level 1 Expert
Ekse
Marvin
Marvin
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
