Question about InFocus LP 600 Multimedia Projector
Infocus LP 600 will not power up! It is not the cord or the outlet. Thanks Paul K
  • gregoryjwhi Apr 05, 2008
    Same problem, I use mine daily and this evening it wouldn't turn on. Tried different cord, outlet, etc. and noticed no led/lcd lights. from other posts it looks like the power board.
  • 563 Answers
Hi Paul
Does the counter on the LCD display ontop of the Projector work ?
If it doesn't your Powersupply board will need replacement.
If the counter does work , it is either your lamp or the Ballastboard ( lamp's powersupply) that is faulty.
Posted on Mar 26, 2008
The infocus LP600 won't power up
make sure the lamp door is engaging the safety switch. manually reset the lamp hours and reflash the software, if that don't work it's most likely the power supply.
May 11, 2010 | InFocus LP 600 Multimedia Projector
The InFocus LP600 won't power up
power supply. this model has a problem with them.
Mar 18, 2010 | InFocus LP 600 Multimedia Projector
I have two InFocus LP 540 projectors that simply do not indicate power when they are plugged in. Has anyone else experienced problems with the power supply? Is there a fuse somewhere that might need...
you can check the fuses (located on the power supply board where the cord plugs in), but it's more likely that the caps are dried out and need replacing, or the whole board itself. if that's the case, try av solutions in ny. they're an infocus service center and they're really good. www.avsolutionsny.com
Jan 22, 2010 | InFocus LP 540 Multimedia Projector
InFocus LP240 Projector won't turn on.
there is a fuse on the power supply next to the plug (on the inside), but this model of projector has power supply issues. the biggest being that infocus no longer has parts, schematics, or component cross references for the lp240. the circuit boards were made by another company that made had their own components and now no longer makes circuit boards (they make fans and bearings), and they have no schematics either. so, i'm sorry to say that the machine is doa. there are no replacement parts available and almost no way to fix the old ones.
May 19, 2009 | InFocus LP 600 Multimedia Projector
Infocus lp 540
Also having this problem."Warming up" then "lamp didn't strike" then "retrying" stuck in a loop. It's at a school where I work and nobody has reported any messages regarding the lamp hours.
Jul 20, 2008 | InFocus LP 600 Multimedia Projector
Self Shutdown of my Infocus LP600
power supply problem. if it was overheating, it would go into cooldown mode then standby. there is an issue with the power supply, and it needs replacing. it's about $100 from infocus.
Jun 16, 2008 | InFocus LP 600 Multimedia Projector
Power problem.
there is a 5amp 250v ceramic fuse mounted inside the case besides the power lead connector.
do not be tempted to use a glass tube one as it will blow due to the heat
Mar 04, 2008 | InFocus LP 600 Multimedia Projector
InFocus LP600
If the counter expired, then the reset is holding both volume keys down for 10+ seconds.
Feb 27, 2008 | InFocus LP 600 Multimedia Projector
Power point conectivity
PowerPoint is a computer program. It has to be running on a PC for it to connect to a projector.
Apr 12, 2007 | InFocus LP 600 Multimedia Projector
InFocus LP 600 Multimedia Projector Logo
462 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
