This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
Mine (same model) does the same thing. The only way I get it to work is to open the freezer, and move the metal ice lever arm up and back down again. Then it starts. But after a day, the arm stops moving and it breaks. I can't stand it anymore.
Before moving into my new house with the mfd2560hes, I had to replace an ice maker in my whirlpool refrigerator. So, I guess I'll be googling this maytag model and buying an icemaker motor replacement kit.
no!! ? never hear of this kind of vodo treatment :) what is your model#? and what is it doing now? is the compresor working? is the fan in the back runing?
I had the same problem-only one of my programs would work, and the rest of the buttons (even start) would not work. I used some scissors and carefully cut about a 1/2 inch in the plastic inbetween each of the copper strips in the ribbon cable. Then I seated each one individually (put them back in the white plastic thing) until I found the one that was freezing all of the other buttons up. Now all of my buttons EXCEPT for the one that was working before work. I can live without 1 program if it saves me $300
PS-mine also stopped working after we moved it, but when I told an "expert" that he said it wouldn't just stop working because I moved it....I think moving it DEFINATELY had something to do with it.
If you laid it down while moving it and did not let it stand upright for a few hours before using it, the sealed system is stopped up with the oil which should be in the compressor. cut it off and wait a day and try again.
Hih, Check and see if something has stopped the condenser fan motor down by the compressor from turning. Sometimes this happens in a move. Also make sure the controls didn't get turned to wrong settings. Make sure evaporator fan motor is working in freezer and that there is no frost building up on the rear panel. Just some ideas to help you. lease let me know if I can assist you further.
Did you find icemaker solution? I have the same unit. Ice maker worked perfect. Then moved to new house, icemaker stopped working. One day it worked (old house), the next it stopped (new house)!
