First thing first is to focus. All you need to do is to enter "regedit" after clicking Start >> RUN. Under REGISTRY EDITOR screen click on "HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > Class >{4D36E965-E325-``CE-BFC1-08002BE10318}. Please highlight "{4D36E965-E325-``CE-BFC1-08002BE10318}" and then on the right pane of the window/Registry Editor, you can see either Lowerfilters and Upperfilters. From then all you need to do is to highlight and then make a "RIGHT CLICK" from the mouse and select for "DELETE" option. After deleting either Lowerfilters and Upperfilters just exit out from Registry Editor screen and shutdown your laptop. Then after 1 minute have to turn it back on then retry checking if it ables to shows up your OPTICAL DRIVE or not. Thank you.
you might have to physically unplug the leads for this
cd/dvd then plug them back this should activate the found new hardware
wizard or
you might have to uninstall
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
if your computer came with
a motherboard disk the drivers could be on it
click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x
right click you will need to update the driver
or
select properties general troubleshoot, select driver
click to reinstall drivers click update driver
hope this helps
http://download.cnet.com/lg-gce-8520b-firmware/3000-2122_4-10203021.html
The new firmware offers enhanced recording speed of some CD-R
media on your LG GCE-8520B CD-R/CD-RW
wizard or
for this device
or
hope this helps
if you mean DVD DRIVER
wizard or
for this device
or
hope this helps
wizard or
for this device
or
hope this helps
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
