Question about Pioneer VSX-816-K/S Receiver
Pioneer VSX 816
I've been having some intermittent static come through on the rear speakers. Front speakers are just fine. It's intermittent, but can't figure out why. I've reconnected and checked all of the wires. Don't think it's the speakers. Any suggestions?
  • 4,234 Answers
The rear signal is generated and separated internally, if either the processing is not correct or the rear channel amplifier has a problem, you can get this type of behavior. Does the static happen more often at higher volumes or is it purely random? Does changing the volume make the static louder or is it always the same level?
Dan
Posted on Mar 18, 2008
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Trying to fix my Pioneer VSX-816 and when I turn it on it says overload and shuts off. Nothing is plugged into it, and I suspect the STK412-230C chip or STK413-230C chip is bad. Is there any method to...
Unfortuneately no! Regardless, you are better off changing both because of the stress they were both put under. When you change one and not the other it is a matter of time before it goes completely taking the new one out along with it. It is important to check speaker wires for shorts, and speakers to be on the safe side.
Mar 21, 2012 | Pioneer VSX-816-K/S Receiver
Receiver issues- VSX-816 K
the speaker is not broken, its the receiver, cuz i have this model, and now it just flashes a blue light on the power button and it wont turn on. I had the same problem as you before it did wat is doing now. i ran the speakers on my vsx-3900s, and they didnt mess up at all, they only did it on the vsx-816
Apr 06, 2010 | Pioneer VSX-816-K/S Receiver
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
Sound cuts out
No, this sounds like a speaker problem to me.
It sounds like the voice coils in your speaker(s) have been fried.
What happens is the part that is burnt does not funtion, but as you increase the volume/voltage the speaker "jumps" foward to a section of voice coil that is not as damaged.
Check your speakers!
Sep 07, 2009 | Pioneer VSX-816-K/S Receiver
Pioneer VSX-816
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
Dec 20, 2007 | Pioneer VSX-816-K/S Receiver
Pioneer VSX-D498
Perhaps the unit isn't switched to 5.1 Maybe the movie wasn't recorded in 5.1 or if it was perhaps the recording was faulty. Try a known good recording to check the system. Check your outputs and inputs plus your speaker cables. Check the fuse if there's a seperate one for left and right, which there should be. Try swapping the front speakers to the rear and the rear to the front and see if the fault is still with the rear sound. BMW
May 15, 2006 | Pioneer VSX-D498 Receiver
Pioneer VSX-816-K/S Receiver Logo
262 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
