Question about Casio Exilim EXZ75 Digital Camera
Enter Settings Screen on every power on
Every time I turn on my camera it prompts me to enter all the settings (regional/time/date etc) again. This is very frustrating if all I want to do is take a quick photo and have to press the set button about 8 times!
Any ideas? Thanks
  • 477 Answers
Yes on the mainboard you have a cmos chip that retains the settings. Every time the battery is removed it clears the date and time settings. if you have a fully charged battery in it and are not removing it and it is still doing this problem you probably have a bad cmos chip on the main board. replaceing the mainboard is your best bet. You can get these off of ebay for around 20 or 30. repair shop charge more for this 80 and up.
Posted on Mar 18, 2008
How do I set time and date
1. Press Setup.
2. Press 4, and then press 1.
This selects Basic Fax Setup and then selects Date and Time.
3. Enter the month, day, and year by pressing the appropriate numbers on the keypad. Depending on your country/region setting, you might enter the date in a different order.
The underline cursor is presented initially beneath the first digit; it automatically advances to the next digit when you press a button. The time prompt automatically appears after you enter the last digit of the date.
4. Enter the hours and minutes.
If your time is displayed in the 12-hour format, the AM or PM prompt automatically appears after you enter the last digit.
5. If prompted, press 1 for AM, or 2 for PM.
The new date and time settings appear on the control panel display.
Feb 27, 2015 | HP Office Equipment & Supplies
On firefox can't open my email it says untrusted
Pls.check your system date & time is correct ???
Pls Try to correct your systems Date & time on the extreme right corner of your screen.
after change date & time it corrected.
if Problem comes again with Date & Time you need to replace BIOS / Motherboard Battery.
How to change date & time
Option 1>>>
Open the command prompt:
  • Click Start.
  • Type "command prompt."
  • In the results, click on Command Prompt
  • Type the word "time". Type a space, and enter the new time in the following format:
    • HH:MM:SS AM/PM. For example, time 5:34:00 PM, time 12:15:00 AM, etc.
    • Press enter or return.
Type the word "date". Type a space, then enter the new date in the following format:
  • MM/DD/YYYY. For example, date 5/15/2009, date 2/14/1999, etc.
Option 2>>>
  1. 1Open the command prompt:
    • Click the Start button.
    • Click on All Programs.
    • Click Accessories.
    • Click Command Prompt.
  2. 2Type the word "time". Type a space, and enter the new time in the following format:
  3. 3Type the word "date". Type a space, then enter the new date in the following format:
  4. 4Check the clock in the bottom-right hand corner. The time should be successfully change.
Sep 02, 2014 | Google Computers & Internet
I NEED TO SET THE TIME AND DATE ON MY LEXMARK X5470 ALL IN ONE.
Set the printer to factory defaults. Caution you will lose all stored custom settings. You will then be prompted to set the language, country, date, time and time format, your fax number, and name on your printer..
You can reset your printer to the original settings by first turning off the power. Then p
ress the Start Color (green button) + X and keeping the buttons pressed down. Press the Power On button once to power the All-In-One on. Continue to hold the Start Color (green button) + X buttons for the next ten seconds.
When the prompt appears , release the buttons and follow the prompts on the display to choose your language, country or region code, date, time, and fax number.
Use the forward and backward arrows to select your language. Use the checkmark to save the setting.
Use the keypad to enter the date, time, fax number, owner's name, and press the checkmark after each selction to save.
For future reference support information for your printer may be found here.
Jan 21, 2012 | Lexmark X5470 All-In-One InkJet Printer
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
I FORGOT HOW TO SET THE TIME?
From the manual:
1) Press Setup.
2) Press 4, and then press 1.
3) Enter the month, day, and year by pressing the appropriate numbers on the keypad. Depending on your country/region setting, you might enter the date in a different order.
4) Enter the hours and minutes.
5) If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM. The new date and time settings appear on the control panel display.
Note that if your HP all-in-one loses power, you will need to reset the date and time again!
Cheers,
Pelu.
Mar 14, 2010 | HP OfficeJet 6210 All-In-One InkJet...
How do i set the time and date
Hi
Note If you press Start Fax Color but the sender sent the fax in black and
white, the HP all-in-one prints the fax in black and white.
Set the date and time
You can set the date and time from the control panel. When a fax is transmitted, the
current date and time are printed along with the fax header. The date and time format
is based on the language and country/region setting.
Note If your HP all-in-one loses power, you will need to reset the date and time.
1 Press Setup.
2 Press 4, and then press 1.
3 Enter the month, day, and year by pressing the appropriate numbers on the
different order.
4 Enter the hours and minutes.
5 If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
All The Best: Pineworks
Jan 28, 2010 | HP OfficeJet 6210 All-In-One InkJet...
The clock reads 10:30 am when it is 9:00 am how do i reset it
Page 60 in your manual.
You can set the date and time from the front panel:
1) Press <Setup>
2) Press 3, then 1 - This selects Basic Fax Setup, then selects Date and Time
3) Enter the month, day, and year (last two digits only) by pressing the appropriate number on the keypad. Depending on your country/region
The time prompt appears after you enter the last digit of the date
4) Enter the hours and minutes - The AM/PM prompt appears after the last digit of the time is entered if your time is displayed in the 12-hour format
5) If prompted, press 1 for AM or 2 for PM
The new date and time settings appear on the front panel display.
Dec 22, 2009 | HP Officejet 4215v All-in-One Printer
After power down of my ex-z70 camera I have to re-enter the language, date, time and region. What is causing this?
After entering the info on most cameras, you have to press a button for "ok" or "set" to make the settings permanent. Are you doing that?
Sep 15, 2009 | Casio EXILIM ZOOM EX-Z70 Digital Camera
How do I set the date and time
I found this that may help you:
"Set the date and time      You can set the date and time from the control panel. When a fax is transmitted, the
1 Press Setup.
different order.
The new date and time settings appear on the control panel display. "
Jun 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Casio Exilim EXZ75 Digital Camera Logo
122 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
