Question about Toshiba 1360 Black and White Copier
Toshiba 1360 copier
Red wrench light flashes. no response from any controls. C7 appears when clear and 8 are pushed. thermistor checks ok, fuser has continuity, upper fuser roller reads 1.4 ohms when checked. any suggestions?
  • scootertoo Mar 19, 2008
    your suggestion worked. thank you.
  • 87 Answers
Turn it on holding down 0 and 8. Key in 89, press start. press 0, press start. Turn it off and on.
Posted on Mar 19, 2008
THANK YOU VERRY MUCH !
Posted on Oct 29, 2008
Just been given this 1360 toshiba copier 2nd hand. worked 1st time but not now. I have no manual & have red flashing light in shape of figure 8 with line coming out from & will not copy anything....
open the machine and lift the red fuser cover and check the exit sensor make sure that that the flag moves easly then makr sure the registration sensor flag moves easy as well the sensor is located at the black roller in the bottom of the machine there is a cutout in the plate you should be able to see the flag if not it is stuck in the open position the figure 8 is a paper jam error
Mar 07, 2011 | Toshiba 1360 Black and White Copier
Toshiba 1360 C7 code. How expensive is it ti fix
With the unit off hold down clear/stop and 8, ad should apear push 89 start (display will read 03) then 0 start. tis should fix it. -Carl
Jun 11, 2010 | Toshiba 1360 Black and White Copier
I have a toshiba 1370 copier....the repair wrench is flashing and won't let me continue, how do i get the wrench to stop blinking?
switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
good luck.
Nov 13, 2009 | Toshiba 1370 Black and White Copier
Toshiba 1360 Copier
"C7" Faulty thermistor, thermal fuse, or heater element
Sep 16, 2008 | Toshiba 1360 Black and White Copier
Wrench light on and c7 code appear
C7 is a Fuser Error......The hot part where the paper passes through before exiting the machine is known as the Fuser or Fixing unit etc.
There are 3 parts involved and any of which when they fail will give a C7 error code. The Heating Lamp,Thermisor or Thermal Fuse.
This is a live area of the machine so you wouldnt be advised to attempt a repair without at least a restricted electrical license.
More than likely one of the parts mentioned will need to be replaced and then the C7 error count reset through "08"
May 12, 2008 | Toshiba 1370 Black and White Copier
Error c7
You can reset the C7 code, hold down 0&8 power machine up. Then push 87 & print, change the number to 0 with number keys press interupt key, then press 0&9 @ the same time to exit. This should clear the C7. Let me know if you need more help.
Oct 26, 2007 | Toshiba 1360 Black and White Copier
ERROR C7
TOSHIBA 1210 C7 Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
Oct 25, 2007 | Toshiba 1360 Black and White Copier
Toshiba 1360 C7 Error Code
TOSHIBA 1310 C7 Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
The codes are good for several models.
Toshiba 1360
You should be able to retrieve a code for a malfunction by pressing down the clear/stop and 8 keys. then let me know what you get, and we will go from there.
Oct 22, 2007 | Toshiba 1360 Black and White Copier
Toshiba 1360 Black and White Copier Logo
515 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
