Fuel Pressure RegulatorREMOVAL & INSTALLATION
(see Figure
1)
To install:
Fig. 1: Cross-sectional view of the fuel pressure regulator
To determine if the pump is in good condition, tests for both
volume and pressure should be performed. The tests are made with the
pump installed, and the engine at normal operating temperature and idle
speed. Never replace a fuel pump without first performing these simple
tests.
Be sure that the fuel filter has been changed at the
specified interval. If in doubt, install a new filter first. The filter
is an inexpensive maintenance item and should be replaced if old or
suspect. Start the tests with a visual inspection. Check lines for
damage, kinks or restrictions. Make sure all fittings are properly
tightened and that there is no leakage from the system.
Pressure
Test
Volume Test
Hope this helped.
SOURCE: I am trying to find
Have you tried checking with autozone? They can tell you where it is from their computer. I have a 99 k2500 and my fuel pressure regulator is located under my intake manifold, my fuel pump relay is under the hood on the drivers side over the wheel well. I Take It you are having problems starting your truck. Can You hear your fuel pump when you turn the key? Have you checked to see how much fuel pressure you have ?
