Question about Kenwood Excelon DDX-7015 Car DVD Player
Got a dvd/cd player 7inch screen in car, wont read disc,s tried a cd head cleaner was working fine night b4 just keeps saying ,,,no disc
More than likely it could be a internal problem with the radio. Also make sure the radio is secure properly. A lot of the newer radios r very sensitive n will notice the dumbest lil things anymore.
Posted on May 07, 2008
BMW X5 Rear Entertainment System, center screen, player on center console floor. DVD discs cannot be read. CD's play fine. What is wrong?
A. Did you try a second disk to make sure the disk isn't bad?
B. Is the DVD a new format like HD, 3D or Blu-ray? if so it won't work.
Oct 06, 2014 | 2008 BMW X5
DVD PLAYER WONT READ KEEPS SAYING NO DISC YET IT PLAYS MUSIC DISC HV TRIED 5 DIFFERENT DVD DISC,HELP
I assume here that DVD's, by nature, require a lens to be more accurate than a CD, since it is not reading only sound but also video. The lens is most likely dirty. If you can see the lens, get a Q-Tip and clean it very gently with alcohol. If not, purchase a lens cleaner, that will fix your problem.
Oct 31, 2009 | Shenzhen Mizuda DVD-999 DVD Player
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Won't read Dvd/Cd as loaded
It is a problem of the optical head being covered up by foreign particles obscuring the optical lens. Try using a CD/DVD cleaner disc which has double brushes and one add some solvent which comes along with the pack.Simply play it & keep ejecting and inserting the disc makes the disc to spin, till your player starts reading it..............................sodeep
Oct 06, 2009 | Coby DVD-224 Player
Disc Reading Error
my remote wont work recorder
Mar 24, 2009 | RCA DRC8300N DVD Recorder/VCR
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony Televison & Video
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
Player says "no disc" when a disc is inserted
Use a lense cleaner to clean the lense. It will be ok
Aug 03, 2007 | Toshiba SD-P1400 Portable DVD Player
Kenwood Excelon DDX-7015 Car DVD Player Logo
156 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
