Frequent resets my computer frenquently rests itself sometimes... I tried to cool it up a little more and even cleaned it's dust but it keeps doing it... what could it be?
  • Matthew Haynie
    Matthew Haynie May 11, 2010
    At one part I see "rests" and at another I see "resets". Do you mean that it is turning itself off for a few moments, then turning back on, or do you mean that it is going to sleep a lot (little green light turns yellow/orange)?
    Genius:
  • 1,913 Answers
Hi
check your ram try onther ram.
check your power cable ,main power supply earhing problem , smps supply.
clen your proceessor case.
also scan for viruses with avast , quick heal and symantec update definition.
Posted on Mar 24, 2008
SOURCE:
Toshiba e 2040c power shut down and on itself frequently
Sounds like the graphics chips, or processor is overheating & shutting down. Check that the cooling fans are running & they are clean from dust, dirt, or hair. Check that the cooling vents/ports are also clean & not blocked.
May 19, 2015 | Toshiba Computers & Internet
Overheating
I would remove the bottom cover and clean the fan and radiator as a build up of fluff will reduce the cooling.
Mar 23, 2014 | Lenovo IdeaPad Z500 Laptop Computer -...
My denon pma 355 keeps going into standby,it has always done so when it gets very hot,it is now doing it much more frequently,sometimes after only 2-3 minutes use
You might want to get an understanding of why it gets so hot. It's not toaster. Repeated thermal stress wil eventually kill it.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jun 04, 2011 | Denon Audio Players & Recorders
Lexmark/IBM Wheelwriter 1000 Typewriter has been in storage for 3 years. Dusted off/cleaned out today. Types fantastically, all functions work, except it keeps automatically resetting the margins. Tried...
First try a little shot of WD40 on both sides of the silver shaft that the carrier slides on. If that doesn't do it you will have to get some on the carrier motor bearings located in the R. rear corner under the case.
DickyO
Apr 21, 2011 | Lexmark Wheelwriter 1000 Typewriter
I have a ACER 5735 . The laptop shuts down suddenly while its on and sometimes im not able to switch on the laptop and even if i switch on , then once again the power goes off immediately . What would be...
The reason for the sudden shut down of your computer is because of overheating of the 'case', where the CPU is mounted. Overheating can be due to dust accumulation on the heat sink, which prevents dissipation of heat. The possible solution to combat overheating issue is to keep the laptop dust free by cleaning out debris at the vents frequently. Note that a laptop has a much smaller cooling area in comparison with desktops and hence laptops tend to accumulate dust a lot quicker than desktops. This is because all the dust/debris, in the case of laptops, accumulate in the cooling fins.
Get more information to fix Acer shut down issue :
http://supportforacer.iyogi.com/aspire/shut-down-2.html
Hope this information helps you.
Aug 28, 2010 | Computers & Internet
Overheating issue Sony GRT270P
Maybe it's wrong with your heatsink;youcan touch this:
http://www.laptopcpufan.com/sony-laptop-cpu-fans-c-7.html
Jun 27, 2010 | Sony (4-635-961-01) Laptop Heatsink
Fan comes on frequently on hp computer. dust etc
If this is a desktop computer, did you clean out all the dust inside the computer? You can buy cans of compressed air at places like Staples. Make sure you blow the dust out of the power supply and cpu heat sink.
Mar 23, 2010 | Computers & Internet
Computer reboots
Hi cool,
Is your Computer keeps on recycling from booting and never finish to load your OS?
As far as i know you got a problem with you CPU, your computer processor is overheating inside that's why it keeps your PC recycling it's power.
Try to go to the BIOS setup menu, and go to the cpu temperature and you will that your PC is heating up.
Hope it helps & give you an exact reason.
Enjoy.
tnx
-micro
Feb 10, 2008 | Computers & Internet
My dreamcast randomly resets itself!
Its been a while since i've owned a dreamcast.My suggestion wouild be to make sure the parts on the inside are clean.Game consoles are known to collect a lot of dust over a long period of time.I would wipe it down with acohol, since it drys fast and leaves no residue.Your reset button might not be getting a connection.
Sep 20, 2007 | Sega Dreamcast Console
Open Questions:
Dell Printer support phone number +1=855=536=5666+ Dell Printer Customer Service QEFKEFU Dell Printer assistance available 24*7. If you are facing any issues in printer you will get expert assistance through Dell Printer helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. Dell Printer TeCh SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... Dell Printer Tech Support Phone Number +{1-855*536*5666*} to resolve all Dell Printer products. is an American multinational company which was founded by Michael Dell Printer using its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. Dell Printer is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Dell Printer care number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees .Dell Printer CUsToMer cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL Dell Printer CUsToMer cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. Dell Printer CUsToMer cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America. SPOTIFY toll free pHoNe Number {1855536,5666-} to resolve all SPOTIFY products. Dell Printer is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Dell Printer care number, and selling of computer-related services and products. SPOTIFY Toll free Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY toll free number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and vikki services. Dell Printer tech support pHoNe {18555365-666-}} nUmBeR USA Dell Printer tech support pHoNe Number {18555365-666-} to resolve all Dell Printer products. Dell Printer is an American multinational company which was founded by Michael Dell Printer using its company headquarters in Round Rock, United States of America. Dell Printers Support Phone Number for Dell Printer Technical support help. Dell Printer Support is an independent body, which is established with the vision to deliver exceptional technical service for the Epson brands.
Oct 16, 2019 | Dell Computers & Internet
Computers & Internet Logo
22 people viewed this question
Ekse
Alun Cox
