Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Unable to record one tv channel while watching another tv channel
I have been told by Panasonic that it is NOT possible to watch one tv channel while recording another tv channel with my Panasonic DMR-EZ47V connected to my tv and satellite (Direct tv). Is this correct? If this is NOT correct, how do I connect the cables between these devices to permit this. My tv has component video input jacks (2 sets) as well as S-Video input jack. Satellite receiver also has component and S-Video jacks. Appreciate any help you can give me. Panasonic says it is only possible to do this with cable box but not with satellite.
  • Anonymous Mar 13, 2014
    The Easy Setting/Auto Setup did not install all the available tv channels
  • 47 Answers
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Posted on Apr 05, 2008
    Problem Solver:
  • 11 Answers
They are correct, you can only record on the channel you are on.
Old school worked because you could have your VCR set to the channel you were wanting to record and the hit TV/VCR button and watch tv by changing channels on the TV
component and S-video is a choice of one or the other for input/output, not enabling two separate connections.
I would get a DVR with your direct TV setup, then you can do what you want, record while watching another.
Posted on Mar 19, 2008
Your recorder does record to the dvd recorder (but not vcr) while watching something else, IF YOU USE DVD REWRITABLE DISCS OR DVD RAM DISCS. I DO IT ALL THE THE TIME. READ THE SECTION IN YOUR MANUAL THAT EXPLAINS WHAT EACH DISC FORMAT IS CAPABLE OF DOING!
GOOD LUCK!
Posted on Nov 19, 2008
6ya staff
SOURCE:
Recordering with directv
You can record either the channel 3 or channel 4 output channel from the DirecTV box or connect the analog audio and video outputs to the recorder's inputs and use the In1 or In2 inputs.
Apr 21, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
I watch tv via Digital DVD recorder but am unable to see sky tv. Do I need an analogue recorder
You need an analogue receiver to view the co-ax output from your sky box but you should be able to connect via scart
Feb 08, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Is it possible to record one show, while watching another ??
You need to put a cable splitter on the cable. One side goes to the TV. The other side goes to the recorder. The output of the recorder goes to one of the alternate inputs on the TV. Set the recorder for whatever channel you want to record using its internal tuner. Use the TV tuner to watch a show live. Later, set the TV input to whatever you connected the recorder output to and watch your recording. You will probably need to do this to see the recorder menu to set up the recording.
Mar 10, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr-ea38v vertical static
I would start by checking which scart leads are in which connections and check which av channel you have the player on.
e.g. AV1 connected to the TV, AV2 connected to the decoder.
Then the DVD player viewing/recording channel should be on AV2 not AV1. Does he have any high powered/frequency devices close by?
Jun 22, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Watch while recording
Make sure the DVD has RF lead and Scart lead connected in and also BOTH connected out to the TV. When you record from TV use channel numbers, when you record from cable use AV channel, (on DVD). When watching TV use TV channels 1 to 5, when watching Cable use AV channel, (on TV).
Feb 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
How do I flash the firmware for a Panasonic DMR-EZ47V?
According to the Engineering channel schudle there is a new firmware (v.1.13)for the following panasonic models
DMR-EZ27, DMR-EZ47, DMR-EX77, DMR-EX87
This is scheduled to be broadcast on 6-2-08.
http://www.dtg.org.uk/retailer/download_schedule.pl user_offline.gif
Jan 31, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dvd recorder dmr ez47veb
If your cable is connected with just a scart lead (in AV2) you just put the recorder onto the AV2 channel. You need to connect the cable decoder to the recorder via an arial lead to be able to tune it in but there is no need just use the AV channel.
Dec 03, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Watching tv while recording onto vhs or dvd
This could be a couple of problems. I'm not trying to make you feel dumb or anything but sometimes people miss the obvious. Do you have an universal remote? How is your vct wired to your tv? Does your cable go to your vct or your tv first? These sound like silly questions but they are important.
Jun 02, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
1,331 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
