Technics sl-ch530 volume problem
When i play a cd the volume is very low but tape and radio is fine
  • 1 more comment
  • neatneatneat Mar 18, 2008
    now its just come on as normal will it go again I think so.
    What can I do to sort it.
  • Scoorpy May 28, 2008
    Hello. I have a similar problem with the sl-ch530: radio and tape are ok, but none cd audio. All cd control funtions work properly, but no sound! Any help?
  • iturina Dec 01, 2008
    Hello. I have a problem with the sl-ch530: radio and tape are ok, but none cd audio. All cd control funtions work properly, but no sound! Any help?
2 Suggested Answers
SOURCE:
  • 4234 Answers
SOURCE: My Technics SL-DV290 stereo has
This means that the unit can tell that a disc is present, but can not read it. Try opening up the top and cleaning the lens using a cotton swab and alcohol. Let us know if that resolves the problem.
Thanks,
Dan
Posted on Apr 02, 2008
Technics SC-CH530 Barely audible CD player
Have you tried cleaning the unit, there are discs to do that, 4 years is a long time?
Dec 26, 2017 | Technics Audio Players & Recorders
The volume on technics SL-BD22 turntable will not turn up and stays at one volume
Since the turntable itself doesn't have a volume control the problem is with the amp it is connected to. It should be connected to an amp with a dedicated phono socket. It's no use connecting it to a tape or aux or CD socket. These sockets do not have a built in pre-amp for the magnetic cartridge. If your amp doesn't have a dedicated phono socket then you can buy a Magnetic Cartridge Pre-amp that will plug into a tape socket etc on the amp and have the deck plugged into it. If plugged into a none dedicated socket though you can hear it, the volume will be very low compared to other sources. If you have got it plugged into a dedicated phono socket and the volume is still low, then the internal built pre-amp inside your amp for the deck has failed and will need to be repaired. The pre-amp failure will not effect any other functions of the amp.
Feb 24, 2015 | Technics SL-BD22 Turntable
Turntable is playing quiet
Hi, if your not plugged into your amp via a dedicated phiono input, Ie CD or Aux then you need a preamp to boost the line levels. Cheers john. Styluscity
Oct 24, 2012 | Technics Audio Players & Recorders
How do I hook up a graphics equalizer SH-GE70 to the amp SU-A707? I've already plugged in the CD player SL-PG5 and the tape deck RS-TR474M2, but can't see how to wire in the graphic. If I could...
hi,
Try this. You need 4 RCA setreo Chord for this.
1. connect the cd player out to the LINE input of Equlizer.
2. connect the Record out of equlizer to Tape's Record input.
3. connect the Play out of the Tape to the Play in of Equlizer.
4. connect the Line out of the Equlizer to the CD input of amp.
Always Select CD in the amp. And select between tape and CD in the Equlizer.
OK
Aug 22, 2011 | Technics SH-GE70 Home Equalizer
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
I have a 1999 Chevrolet Suburban with the factory radio. The radio works fine but when I put in a cd and turn the volume up some, it just stops playing for about 20 sec. It will come back on at a very low...
sounds like your popping the breaker, after a while your speakers will go, theres just too much power for it to handle, take it to a car audio store and get them to test it, you may need new speakers
Jun 20, 2009 | Car Audio & Video
My Technics SL-DZ1200 will not play certain MP3 tracks. It will play some, but on others the message "track error" appears. these same disks will play just fine on the other cd player machines I have...
I believe it can only read certain bitrates. I noticed that if I run the track error files through audacity and re-save as an mp3 with 192 kbps encoding it plays fine. Give it a try - re-encoding.
Jun 08, 2009 | Technics SL-DZ1200 CD Player
Technics SD-L3 TURNTABLE
Does your receiver have a dedicated phono input? If not you'll need to use a preamp between the turntable and receiver. Your other turntable may have a preamp built in and the Technics not.
If this does not help, please post the brand and model of both your receiver and your other turntable.
Oct 14, 2008 | Technics SL-1210 Turntable
Volume
Please let me know how your turntable is connected to the music system. I mean, to which input ? (Tape/Aux/Phono/VCR/CD) ?
Aug 24, 2008 | Technics SL-1200MK2 Turntable
Technics SL-HD350 Cd Player - Sound problems
This maybe due to overheating of some Sort.
Try taking it out of where it is where theres a good flow of air.
Then try running a cd.
Try Putting in a Cleaning cd, this maybe a fault with the laser.
Regards
Dec 31, 2007 | Technics SL-PG480A CD Player
379 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
