Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Steam vac When the cleaning solution is despened it is coming out in a stream not in a spray. Is this normal or is something wrong? Thanks for your help..
  • 2 more comments
  • 66larry Mar 29, 2008
    How do I unclog the nozzles? The brushes are turning..
  • 66larry Mar 30, 2008
    This may sound stupid but will the vinegar & water stain or mess up the carpet?
  • 66larry Apr 02, 2008
    I ran the vinegar & water thru the system. It sprayed sometimes & sometimes it was not spraying. Just streams came out. But it is better.. maybe i need to run some more vinegar thru the machine...
  • zinda Apr 27, 2008
    MINE DOES THE SAME BUT IT seems that the trigger makes no diference it runs out always and it looks like its just dripping in a puddle while its running. Took apart the machine and cleaned out the upper dispenser valve assembly. I also had a loud whining sound much like a faulty turbo charger on a car. I looked through the lower part of the vac and checked the motor, impeller, casing, and mounting screws, all were in good condition other than a slight tweaking i did to straighten out the impeller. I did however find the problem to be the round object that the attachments plug into. I dissassembled the unit to find that this is a turbo charger of sorts! The suction from the motor spin another freewheeling impeller that has a small fan like pump on one end. The solution goes into this and i'm guessing its pressurizing the water to make it jet spray. this device is really simply made and has nothing to keep any presice tolerances that may be requiered to perform properly, it can easily move on its sharft in or out which directly affects its ability to create any pressure. I have solved my high pitched noise and now have great suction power but this solution draing out is baffling me due to the hose routing they have and need to see a service manual showing me the internal parts better.
    President:
  • 1,673 Answers
Either the nozzles are clogged, or the brush block is not turning.
Posted on Mar 26, 2008
  • Lauren Junge
    Lauren Junge Mar 29, 2008
    Try putting in a solution of vinegar and water and run it thru, if there is any clogs, that will clear it out. If it doesn't, then you may have to have it checked.
  • Lauren Junge
    Lauren Junge Mar 30, 2008
    don't know, but do it on maybe the bare kitchen floor.
SOURCE:
I have the hoover automatic dual vac 5. this is the 3rd hoover rug cleaner i purchased and always the same problem the spray underneth the rotator bars hardly dispenses and the floor hardly gets wet, this...
The carpet is not intended to get soaked, like what you see with a spray application. If you are seeing a stream of water in the nozzle/tank during the recovery stroke, this is working properly.
Jan 17, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Dual V steam vac model F7425-900 won't dispense detergent
Check the spring loaded valve at the bottom of the detergent bottle.
Push it up with your finger or a pencil or some such thing and see
if fluid comes out. If it does, then the problem is the valve or tubing I
would suspect.
Tom
Oct 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steamvac won't spray water/cleaning solution
Clogging of the pump that sprays water/cleaning solution is very common in Hoover and Bissell Steam Vacs. Try running a cycle of 1part vinegar or CLR to 3 parts warm, distilled water through the vacuum pumps. The heads get clogged with soap and the water pumps get clogged at the opening of the flash heater due to minerals in hard water. If you want to extend the life of your steam vac, don't use the heater unless you are using distilled water. This can get expensive, so I recommend not using the heater.
Sep 11, 2009 | Hoover F7431-900 SteamVac Vacuum
The brushes on my steam vac won't spin
I used the suggestions found from a previous question found on your site.. thanks though. will recommend your site to all.
Aug 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Water will not spray out and pick up
My steam vac wont spray out the cleaning products.
Feb 15, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac dual v makes humming noise and nothing else.
Is the overfill valve (the yellow thing) in the waste container stuck in the up/full position? Maybe it just needs to be rinses well to avoid it being stuck and shutting off the vacuum portion of the cleaner.
Oct 09, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
We purchased a Hoover Steam/Vac (F5915-900) cleaner. We assumed it be a combination STEAM and Vacuum machine. Where is the Steam? I will await your reply. Thank You.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761645
Generic problem for all Vacuums
Posted by hjopmi on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I have a similar Hoover “SteamVac” and the vacuum does not create steam as you stated, but you do have to use the hottest water with cleaning solution and the Hoover will clean your carpet by spraying down the solution, the scrubbing brushes will loosen the dirt and the vacuum will pickup the excess water until the holding tank is full and then you have to empty it, and then start again. The word “Steam Vac” is something that the Hoover factory labeled but so far I have not seen anything that actual produces “Steam” while cleaning. Feel free to contact the Hoover factory with your complaint @ the information listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Steamvac
You might try running a solution of vinegar and water thru it to clean out the lines and spray nozzles. Also are the brushes turning when you are using it, that could also be the problem.
Mar 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
147 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
