Question about Samsung 710V 17" LCD Monitor
Screen goes black and no backlite when connected
When the monitor is not connected to a source then it displays that there is no connection like a normal situation. When i connect a pc the picture goes black and the backlite turns off. With another monitor it works fine.
Powersupply seems to work alright.
Please can you help
    Sergeant:
  • Samsung Expert
  • 406 Answers
Please reduce the resolution/ Frequency of your Display Card in system and see whether you can see some thing. Else connect this monitor to another system with low resolution. Let me know your feedback.
Posted on Mar 18, 2008
It's a problem with this model of Samsung monitor. Somebody tells me to put monitor off (pull cable from electric supply, not just turn off) and wait 3 minutes. And monitor works.
Posted on Jun 23, 2008
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
How disassemble vg700b monitor backlite not working
I suggest you connect the VGA cable from the computer to another monitor or a laptop, just to make sure that your monitor's back light is faulty. If it does show on the other monitor or laptop, then the back light is really faulty. And i suggest that you get a computer technician to open it up for you if you can not do it yourself. Or you can get a sharp-flat object and open the monitor starting from the bottom of the monitor working your way round to the top. You will notice finger-like structures that hold down the monitor covers together. Make sure you do not break any of those. When you open it, check on the circuit board where you connect the power cable. Check for any bulged or leaking capacitors. Capacitors have a job to hold down the power from the source long enough for your display. For faulty capacitors, the monitor will either remain black with the orange light blinking, or it will display for at least between 2 to 8 seconds and then goes black. Buy the same type of capacitors and replace the damaged ones. Please not the polarity as you replace the capacitors.. Good luck
Feb 21, 2012 | Samsung Viewsonic VG700B Monitor
My screen on my laptop went black.
Theres is a lot of reason associating to a black screen. First lets just assume it the screen and not the laptop. Check to see if you still see any image in the screen, you might want to do this in a lighted area. If you do, but is very dark, then your backlit light is dead and your screen needs replacement. If you don't see anything, then use a external monitor such as a computer monitor, a Tv and connect via VGA port, or HDMI if you have one or a svideo to an external souce and see if you get picture, If you do, then your Inverter is bad, or either a loose connection wiring somewhere between your comuter base and your screen. ( Because laptop tend to open and close alot) If you don't get anything via external source through your VGA, HDMi or s-vdeo, then this is something involved with your laptop. Could be from cpu, chipset, ram, or simply the motherboard itself.
Jan 28, 2011 | Computers & Internet
My laptop comes on, but the monitor doesn't. Any clues as to why? Thanks/
To make sure you have a bad screen or a bad backlit for your monitor, you want to test an external source using your external vga outlet or a s-video hdmi port if provide to a external monitor such as a TV. If you are able to get display to them then, your promblem is with the screen. If not, then it could be your VGA chipset that is damaged. If you do get a display to a external source, you want to see if the monitor does display anything, If you do see something and it's really dark, then it is your screen backlit bulb that is dead and for that you need to replace your screen. Now if you totally get nothing, then it could be a loose connection wiring between your laptop and your screen since laptop tends to bend back and forth suffering from daily useages and the laptop may need to be opened up to see if there is a loose connection, or torn cable.
Jan 14, 2011 | HP Pavilion dv9730us Notebook
My travelmate 6460 it is working but can't see anythng on the screen please help
To make sure what is really wrong we need to break down couple of things, have you tried connecting a external source such as to a monitor or a tv via s-video or vga. If it is able to display to the external source then there is something wrong with your screen. Now is it completely dead and you cannot see anything or are you able to see something but the display lights are not litting the display. If that is so, then your backlit is dead and you will need to replace the entire screen. In my honest opinion if that is the case I recommend you to by a new laptop, because parts/labor cost would cost more then your medium powered new laptop.
Jan 14, 2011 | Acer TravelMate 6410-6248 (LX.TCX0Z.032)...
Monitor stays on for 1 sec and goes black
sorenke, Monitor "switchmode-mode-power-supply" going into shutdown mode when detecting a FAULT CONDITION with some other circuit or with itself. Your monitor has same technology as any other backlit lcd display!! Read more of my responses to owners that have BLACK screen problems. Some have BLACK and BLANK screen problems Do you know flashlight test of SMPS status? How old is unit? How many Total "ON" hours unit have? Do you know what a bad electrolytic filter capacitor looks like? Have you been to YOUTUBE yet? 12fixlouie
Dec 15, 2009 | Hannstar I-Inc TW-191D Monitor
Lcd screen goes black after a few seconds
check your vga cable that is connected on your cpu,for some lose connection,it must be fitted if you still don't get any display check your cpu.have some other monitor for isolation,if you dont have bring it on s repair center,your cpu has a problem.
Sep 10, 2009 | Computers & Internet
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Samsung SyncMaster 215tw screen goes black after about 1 sec.
I have the same problem its defenitly a problem with the lcd monitor not with the graphics card nor the pc. I hooked up the digital and afterwards the vga connection both had the same result. 1 s perfect screen all visible but than black. pushing the on/off or standby button again shortly 1s the display works than it blanks. Did the same test while connected to a dvd player via the composite video... same problem . Since the previous posts are that old and without a solution I guess there is no hope in getting it fixed.
Jan 20, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung 710V 17" LCD Monitor Logo
170 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
