Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Manually Adding Digital Channels to the Panasonic DMR-EZ37V
Just recently "updated?" to the 2008 PANA_DVD.FRM file listed on the Panasonic Drivers and Downloads and updated the firmware of the DMR-EZ37V. All seemed to go well until I attempted to add back in the Channel Programing. The previous firmware (more than likely original) allowed manuals additions to the channel list automatically programmed by the setup (antenna-based). This latest firmware does not work the same way. The DMR-EZ37V is used in a fringe area and the antenna must be pointed pretty much directly toward the channel in order to pick them up. Before the update, just setting the channel to the correct channel frequency used by the digital station, added that digital channel to the list of those already programmed. Does anyone have a suggestion on how to either go back the original firmware (somewhat buggy) or how to manually add channels to this unit?
SOURCE: DMR-EZ37V NO POWER!! HELP!!
Return it to where you bought it.
Posted on Dec 28, 2007
SOURCE: dmr-es10 dvd recorder - cant get the machine to record digital channels form tv
Channels 1-5 are I believe for Analogue reception. To record from my digital Freeview box, I'm plugged into SCART port 2 (bottom most port on right hand side of machine as you look at it from the front). Use your remote to change the channel to A2 with the <CH> rocker button just above the video+ button on the controller. This will then record whatever channel your freeview box is set to - the only pain is you can't watch a separate channel whilste recording.
Kind Regards
Brad
Posted on Apr 29, 2008
  • 12 Answers
SOURCE: DVD Recorder Is Unable To Find Digital Channels
Try resetting it here is the procedure
1. open thr front lid
2. press and hold for 5 sec. the up and down buttons.
this will reset the clock and the channel settings
Ihope this helps
Posted on Jul 11, 2008
  • 70 Answers
SOURCE: Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Posted on Jul 28, 2008
jaffa012001
  • 376 Answers
SOURCE: need a copy of owners
http://www.retrevo.com/support/Panasonic-DMR-EZ37-DVD-Players-manual/id/3822bh951/t/2/
Posted on Sep 10, 2008
Is there a firmware update for panasonic dmr-e75vp
It is possible to update the firmware on your unit, provided that the firmware you download is not already installed on the machine.
In order to install the firmware update you would need to :
1. Visit Panasonic's website at Panasonic.com
2. Click on the 'Support' link and then type in your Model No. DMR-EH75
3. Click on 'Drivers and Downloads'
4. You may download the firmware by clicking on the 'Download' link
5.After the firmware has been downloaded, you will need to burn the file unto a CD-R
6. After successfully creating the Firmware disc, place the disc inside the unit to begin the update process
7. The unit will indicate when the update process is finished
8. There is also further detailed instructions on the 'Download instructions' link which is found beside the 'Download' link.
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-EH75VS.D#ts
To obtain additional troubleshooting assistance for your product, please contact our Panasonic Customer Call Center at (800)211-7262. The hours of operation are Monday through Friday 9AM to 9 PM. Saturday and Sunday 10 AM to 7PM Eastern Standard Time. A representative will be available to assist you. Please have your case number, which is listed at the top portion of your email, available at the time of the call.
Aug 24, 2011 | Panasonic DMR-E75V DVD Player/VCR
Need remote code for panasonic dmr-ez37v
Hello
Setup code for Panasonic DVD recorder with "Atlas Metrocast [Universal electronics] DVR-PVR 5-device universal remote control" is:
0490
For DVD players, codes are
0490, 0632, 0703, 1362,
1462, 1490, 1762
OK.
Jul 02, 2011 | Panasonic Televison & Video
I have lost the instructio manual for my vhs/dvd
Click HERE to download DMR-EZ37V user manual copy.
Hope that will provide you proper info about recording.
If above link does not work, click HERE.
Thanks.
Aug 05, 2009 | Panasonic DMR-EZ37VS
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Remote
When I have the same issue with my dmr-ez37v I recover by unplugging the unit for about 15 seconds, then plugging it back in. It seems the unit get "hung" about once a month and requires a hard power reset.
Regards,
Bob Headrick
May 19, 2008 | Panasonic DMR-EZ37VS
Dec 26, 2007 | Panasonic DMR-EZ37VS
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
387 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
