Service Code We have a Gestetner 2430 copier and it will not do anything but displays C 61 call for service. Can we fix this ourself?
  • 38 Answers
TRY CLOSE ALL THE COVER PROPERLY
Posted on May 12, 2008
Gestetner Dsc445 service code error
have you checked/replaced the thermostats?
this may also be a problem with your hvt board or power supply.
Feb 26, 2013 | Gestetner Office Equipment & Supplies
Could you please send me the keys code for dsm 645 copier
On the display the message came up to call for service with the code SC546what can I do to fix it myself. the machine is not working for printing. machine is ricoh modle SDm645
Jan 22, 2013 | Gestetner DSm645 Digital Imaging System
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
I have Gestetner DSM622 SP, Iam getting Errer code SC546, can someone explain me thanks
sc546 is a fuser temperature detect error. One or both of the thermistors most likely need to be cleaned or replaced, but you will have to go into service mode to reset the code once you do that. You should contact your local service technician or Gestetner dealer, as they can easily fix that problem.
May 13, 2010 | Gestetner DSm622sp Digital Imaging System
I have a Gestetner 3245 With Code SC 322-00 call for service message on. What is it, can it be fixed or reset. I bought it used to use in my classroom. Thanks
Hello sir; The error code you display on screen, it means laser unit have problem, it can not be reset but it can be fixed, you have to call your local technician to help you.
Oct 13, 2009 | Gestetner Office Equipment & Supplies
How can reset fixing error for gestetner copier
The Gestetner and Infotec copiers is based the RICOH.Please try the Ricoh sercice enter code (press total clear key(yellow) -1-0-7 and press and hold down the C key more 4 second.Eneter in the service mode and turn OFF the copiers,unplugged the cords.Wait 10 sec.amd plug in the cords and turn ON the power switch.If is not good the 107 code try 104 or 102.
Aug 19, 2009 | Gestetner Office Equipment & Supplies
When turned on it says to contact service provider.
It's a fuser (warm up) error.
Can only be reset in service mode by a technician once the problem is solved (lamp, fuse, or thermostat, etc)
Mar 24, 2009 | Gestetner Copier
Gestetner DSM645SP Error Code SC 322
After research it seems this problem is not easily fixed.
Jan 16, 2009 | Gestetner - DSm645sp Digital Imaging...
Help with code sc546
need model.but in most it's a fuser prob.
Jul 05, 2008 | Gestetner DSm645 Digital Imaging System
jasbo
jasbo
