Remote control commands of the remote not working ex input does mute
    Problem Solver:
POLOROID SENDING A NEW REMOTE
Posted on Mar 19, 2008
SOURCE:
RCA fios remote a/v button mutes TV instead of switching inputs. Mute button does nothing
Remote control damaged. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Mar 26, 2014 | RCA Televison & Video
We own the Logitech Harmony 550 universal remote and recently purchased the Insignia NS-L32Q-10A for some reason we can't get the Logitech to work with the Insignia, any suggestions?
Does the device not respond at all?
You can try learning the commands from the original remote to ensure that they are correct.
1. In the software, click 'Learn IR' next to the icon for the device. 2. Go through the list of commands and learn the ones you think you will need by clicking 'Learn'.
The important commands of course are the power commands and input commands. Also channel and volume commands.
Hope that helps :)
Apr 05, 2010 | Logitech Harmony 550 Remote Control
Not connecting proper audio input
Try:
Learning the input commands for the audio device.
Increasing the inter-device delay and power-on delay for the audio device.
Mar 02, 2010 | Logitech Harmony 550 LCD Remote Control
21.0ir remote will not list all inputs on tv
Hi dbcypertI was going over your post and seen where there is a problem with the DISHNetwork remote not being able to go to all the inputs on your TV. If you pushand release the TV button and try the volume, mute and input and it still isnot working replacing the batteries. Then we have what we call a Power Scan andI will send the link to help with these steps. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Sep 26, 2009 | DISH Network IR Remote Control
Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
Aug 17, 2009 | Directv RC-64 Remote Control
Can't select front input without remote
I had the same problem, had a universal DirecTV remote that was able to control the volume/mute, power and channels (both TV and DirecTV), but the input button didn't work. There was no av/tv button on the front of the tv, and the autoregistration of channels didn't pickup the gamecube on the AV channel. What solved it was simply to press "00". I couldn't believe it, but it was that simple. Hope this helps you like it helped me, since the tv was not going to be of much use since we were using the RCA inputs, not the coax. Didn't want to try to conver the RCA to coax either.
Apr 04, 2009 | RCA F27440 27" TV
Programming Harmony 880 Remote to Mute with CC on Sony Bravia KDL-40W4100
Do you use a Home Theater receiver along with your televison?  Are other components, such as a DVD player, VCR, Blu-ray player, etc. connected?
If so, it's possible that the Mute function on your remote is muting the sound from your receiver, and not the TV itself.
If that's the case, you'll need to look at the details of the "default" buttons for your activities, and see whether the Mute function is associated with your TV or your receiver.  If it's set for the receiver, you need to change it to be associated with the TV.
Oct 30, 2008 | Logitech Harmony 880 LCD Remote Control
Logitech harmony 550 volume problem
I would call or email in to logitech and suggest that they copy some of the learned commands for your bose system into your harmony remote account.
The commands they add are learned from other customers and they will only copy the best ones. Give it a shot.
Jul 21, 2008 | Logitech (9662080403) LCD Remote Control
No code for Polaroid LCD TV
Code Polaroid 1250.
if it does not work try SEARCHING FOR CODES
If none of the codes listed under
“Device Codes”on the back of this
guide match your device, you can
search for a set of commands that will
work. Your remote will sample all the
codes in its system for that device
mode to find one that will allow you to
control your device. 1. Press and hold a device mode
key (AUDIO, DVD/VCR, or TV) for
at least six seconds. The LED for
each device key lights up, then
the key for the device you
selected remains on. 2. Press a function key (such as
Power or Mute). The following
function keys are valid for
Searching (Power is
recommended):
• Power
• Mute
• Play
• CH +
• Stop
The device key’s LED blinks
three times, then turns off. 3. Press (up) The remote will send
the IR command for the function
you pressed in Step 2. 4. If the device performed the
function you pressed, press OK.
The remote will now control the
device you selected in Step 1.
If the device did not perform the
function you pressed, repeat step
3. Press (down) to retry the previous
code. rmarti Colombia
Apr 05, 2008 | Motorola Mobility DRC800 Universal Remote...
Remote dont work with my tv
hi go here for the complete usermanual, and try thid following.
Searching (Power is
recommended):
• Power
• Mute
• Play
• CH +
• Stop
3. Press !. The remote will send
3. Press " to retry the previous code
I hope this helps
Please rate accordingly
Thank You
sserpentio
Mar 28, 2008 | Motorola Mobility DRC800 Universal Remote...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
