Question about Sony Ericsson W200i Cellular Phone
W200i speaker not working
Hey bro am akash from delhi ma w200i was dipped in water ander it i cleaned it with solution and dryed with hot air gun and then everything is working in it but speaker and joystick is not working joystick is workin up and left in functions and in game its all working please tell me how to solve and if u can contact me this is ma no.9971832028
    Brigadier General:
  • 7,752 Answers
Take the phone to a professional service center and have them replace the speaker and fully service the phone.
Posted on Mar 23, 2008
SOURCE:
Vas pet 3. The motor is "blocked". How can I clean it?
Take it out if you can and take a good air hose through it or if you can not saying put it back together for 24 hours dip it in water n soap make sure it's dry then get a grease gun and hit the moving parts of the motor with grease and put the motor back in plug all wires back up the right way and done
Apr 03, 2016 | Vacuums
Tip
How to clean your air brush to keep it like new
Taking care of your tools and supplies is an essential in their upkeep and increasing the life of your tools. When you neglect to take care of your tools they will get clogged or ruined and eventually will stop working. This same principle applies to your air brush gun, if you don't take care of it and clean in properly after each use it will get clogged and will stop working.
After each use you want to make sure that you get all the paint out, to do this you should add a little bit of warm water to the cup (where the paint goes in) and then pour it out into the trash. You must be sure NOT to use hot water because it could melt or warp small plastic pieces inside the gun.
Fill a bowl or tub with clean warm water, connect the air brush to the tube, plug it in and turn it on. Placing the needle and the cup under the water and pull the trigger. Run water through it for a few minutes to make sure that no color comes out of it. If paint does come out of the gun you will need to change the water.
When the water runs clear through the gun take it out of the water and fill the cup with clean water. While placing your finger over the needle cap pull the trigger. This will make the air flow backwards through the gun causing bubbles to form in the cup. If there is paint stuck in the gun it will come up in the bubbles in this step. Pour the water out and place the needle and cup in water again and pull the trigger.
When you feel that it is clean, take the gun out of the water and spray your gun on a white napkin or paper towel to make sure there is no color in the spray. If no color comes out you are all clean and ready to use your airbrush gun again.
on Feb 06, 2014 | Air Tools & Compressors
I have an HP Designjet 430 with colour kit. Hasnt been used for a while (maybe 2 months). Cartidge light flashes. Have cleaned all cartridges and checked that they are installed correctly and are full but...
Hi Laura.
A trick I've used from years back seems to work, if jetsare maybe blocked from dried ink.
You will need:
An old or disposable container and clean rag.
Some clean tissues.
Hot water.
Sheet of paper. Newspaper will do.
Cleaning jets:
Pour boiling hot water into container.
Dip base of cartridge 1 into water until you see an ink-cloud then remove and pat dry with clean rag.
Rest at angle on paper.
Repeat for other cartridges.
Use tissue to gently wipe any remaining water drops.
Reinsert in printer.
Regards, Clive.
Nov 21, 2017 | HP DesignJet 430 InkJet Printer
Penny got stuck in console
  1. Remove the batteries from the Wii Remote.
  2. Get a clean toothbrush (no toothpaste) and a cup of warm tap water (not too hot). Do NOT pour or submerge the Wii Remote in any type of liquid.
  3. Slightly dip the toothbrush in the water (the toothbrush should not be dripping wet) and scrub the area of the Wii Remote around the buttons.
  4. Work the bristles down around the sides of the buttons.
  5. After cleaning the Wii Remote, dry it off with a paper towel.
  6. Let the Wii Remote air dry with the buttons facing down for at least a couple of hours.
  7. Test the Wii Remote for proper response.
  8. Repeat the steps if necessary.
Dec 26, 2010 | Nintendo Wii Console
Canon pixma mp130
1. Take out black and coloured ink cartridges.
2.Clean golden contacts with a q-tip dipped in alcohol'both on the print head and on the cartridge.
3. Dip the cartridge in a hot water bowl, let all the ink left flow out.
4. Wipe with a paper towel.
5. Let the parts dry out for at least 24 hours
Oct 03, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Running rough. no gas going to front plug. Took carb off cleaned it . cleaned gas tank.put new gas in tank. all lines are clean and free. plug fireing but black and dry.
If your plug is dry, then there is no fuel. This can happen for two reasons: No compression - be sure to get a compression tester and ensure that there is enough compression produced by the engine to enable the engine to run. More than likely, though, there is no fuel getting to the engine. When cleaning carburetors, it is important that you use a chemical dip. Spraying carb cleaner through it is not enough. Be sure to disassemble completely: fuel float and its needle and seat, all jets, all emulsion tubes, all air cut off systems and accelerator pumps, all enrichment circuits (choke), vaccum slide and diaphragm, all air jets, and last but not least - the idle air/fuel screw. If this is the first time the carb has been taken apart you have to drill the cap to get to the screw. once everything is apart, soak all metal parts in the Berryman or equivalent chemical dip solution for at least several hours. After, run hot water, as hot as you can stand over all dipped components and blow out with compressed air. reassemble and enjoy.
Sep 25, 2009 | 2001 Yamaha V Star 1100 Classic
Color is separating (red and Green double images
Yes everything is repairable.....
The problem is in the Croma section of the TV
some times it ma happen due to 99% of moisture.........
Try Hot air Blow drying for 1 HR in side the TV i.e on the circute and blow clean if any dust partical are there
and then re check
if the problem prestis....contact the TV repai expert or the service centre....
May the Croma chip needs replacement....
Regards
Sep 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
DECLOGGING DRIED PAINT VEINS IN MANIFOLD
You can't hurt it any more than it is, so I would try a liquid paint remover/stripper and let the metal parts soak over night. I'd be more careful with the plastic parts. Poke in the holes with a fine wire (paper clip) or pin. About the service manual, use a search engine (Dogpile, google) and search the web.
May 31, 2009 | Campbell Hausfeld Air Tools & Compressors
Remote don't work?
hi i am sunilsingla from punjab ok your remote is not working open the remote ok wash the remote plate of use the water and rin soap and dry the plate of air bloer and dry the hot gun ya gas out the water ok call 09810442895
Feb 10, 2008 | Hauppauge WinTV-Go Plus (85428010335) TV...
Kenmore AC2044-1 question ASAP!
If it says "Clean Cell Now" and it is a new machine, it is broken. I have six, yes six, of this model. They are all new and you shouldn't have to clean the filter/cells for a few months.
The way to clean is:
  1. Unplug
  2. remove the white cover
  3. remove the prefilter. Good time to clean the prefilter by removing the 2 retention clips and gently swing the prefilter outward. Clean or groom it with a vacuum. Use the upholstery brush. wash the prefilter in warm, soapy water. No Chlorine! Rinse clean with regular water. Wipe with a paper towel and let dry completely. It is okay to gently use a hair blower to speed up the drying process.
  4. Onto the Cell.
  5. The cell can be washed one of two ways. Either in a hot tub of water or in a dishwasher.
  6. Wear gloves to protect your hands. Never touch the fins or wires. It will ruin them and cut you up. Use the two handles.
  7. Use hot water and dish detergent.
  8. No chlorine and no abrasives.
  9. Soak for 10 minutes, then dip a couple of times to remove stuck dust/dirt/schmutz.
  10. Rinse with clean water.
  11. Allow to dry
  12. Allow to dry
  13. Allow to dry
  14. Okay to use a hair dryer to speed up process.
  15. Reinstall
  16. Power up
  17. Press and hold CHECK button for 3 secs to reset.
Thanks.
Jan 10, 2008 | Kenmore AC2044-1 Air Purifier
Sony Ericsson W200i Cellular Phone Logo
119 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
