Question about Brother MFC 210C All-In-One InkJet Printer
Brother Machine Code 41
My MFC210C shows Unable to Print. When I access Maintenance it shows Machine Code 41. What does this code mean?
  • 832 Answers
Error 41: ph is defective and needs replacement.
Posted on Mar 19, 2008
Unable to print 32 printer brother mfc 9490cw
Unable to.....
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine
Sep 15, 2011 | Brother MFC 6490CW InkJet Printer
Unable to clean,need code to reset MFC210C, I
Error "unable to clean" on Brother MFC Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 03, 2010 | Brother Network Ready All-In-One InkJet...
Unable to print 51 - what doe it mean? I have had Brother MFC-440CN, it has worked well... However, I got error msg "no paper" althought the tray was full of paper; tried to fixed - on/off; delete/add......
Hi Ok try this it may work.
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
Solution:
· Machine off
· Press 80
Jul 11, 2009 | Brother MultiFunction Center MFC-440CN...
Brother MFC 210C Machine error 41
Error 41 refers to the printheads which is a common problem with Brother machines. The printheads will need to be replaced. On some machines, Brother has extended the warranty to cover printheads because of the excessive failure rate. Contact Brother to see if you qualify and they may send you new printheads along with easy instructions to replace them. Also please rate this solution with a fixya rating. Thanks!
Dec 27, 2008 | Brother MFC 210C All-In-One InkJet Printer
Hi, I have a Brother MFC-210C that keeps telling me its unable to clean, I followed the user manual but it keeps displying the same message, what do I do now? please help
For Brother MFC210C Printer Fax Copy Scan
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode).( "The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.") Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
Dec 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc-210 printer says unable to change or unable to clean there is nothing caught in printer and trurned it on and off several times
This is on this website somewhere. I used it and it certainly did fix my printer! This is what I did:
"1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights will flash when in maintenance mode).( The user can establish the internal Machine Error Code as follows: pull the main power cable out of the machine (power off). While holding down the Menu/Set key, re-insert the main power cable into the machine (power on). The internal Machine Error Code Access will be displayed.") Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Carry on printing !!"
Jul 05, 2008 | HP Deskjet D4260 Printer
Brother MFC 210C
I am unable to clean and ended up with these notice (unable to print see troubleshoot in user's guide book).pls send the solution to the e-mail address provided.
Apr 03, 2008 | Brother MFC 210C All-In-One InkJet Printer
BROTHER "MFC-3820-CN" TROUBLESHOOTING
You need a new print head.
You could try cleaning the one on there, but all brothers similar to yours are plagued by this problem.
To clean it try:
SWITCH MACHINE ON WHILST HOLDING DOWN MENU/SET KEY, THIS PUTS MACHINE INTO FACTORY SETTINGS MODE.
(MAINTENANCE WILL SHOW ON LCD)
ENTER CODE:84 & WAIT WHILE MACHINE PERFORMS A FORCED CLEANING CYCLE.
(cLEANING WILL SHOW ON DISPLAY)
NOW ENTER CODE:09 & MACHINE WILL PRINT OUT ITS PRINT QUALITY CHECK SHEET.
(IGNORE INSTRUCTIONS PRINTED ON CHECK SHEET)
CHECK QUALITY & REPEAT BY USING CODE:84 IF NEEDED.
(YOU MAY HAVE TO DO THIS SEVERAL TIMES BUT YOU SHOULD SEE A STEADY IMPROVEMENT WITH EACH CLEANING CYCLE)
WHEN FINISHED AND QUALITY IS GOOD, ENTER CODE:99 TO RETURN TO STANDARD MODE.
PRESS MENU/SET 4, THEN MONO FAX START TO PRINT OUT
PRINT QUALITY CHECK SHEET & FOLLOW ON SCREEN INSTRUCTIONS.
Feb 11, 2008 | Office Equipment & Supplies
Brother MFC 210c
press menu then start bc copy then 4 times arrow up. What error code does the machine display.
Dec 12, 2007 | Brother MFC 210C All-In-One InkJet Printer
Unable to print. Error message Machine Error4F
here read this:
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001887&Sympt=How+do+I+clear+the+message+Machine+Error+4F+from+the+display%3f&Model=89&ProductGroup=5&ProductID=MFC210C
Dec 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
278 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
