Have an 8790 with the bad MOBO, getting the artifacts on the screen. Understand the video card is permantly attached to the board. How much to replace?
Im 12 how am i supposed 2 no! lol
Posted on Mar 18, 2008
SOURCE:
I hav a asrock p4i45dv mother board , its cpu lights appear but nothing is displayed in monitor may i know the cause of this problem and soluton
This is either a bad monitor, a bad video card (if you're using a stand-alone card), or a bad motherboard. Test the monitor by connecting it to another computer. If the monitor works, then it's the video card or MOBO. Use a stand-alone (PCIx/AGP) video card that you are certain works. If this does not work, then the MOBO is not working. I hope this is helpful and best of luck!
Sep 21, 2011 | Asrock P4I45GV R5 Motherboard
Hi, I have an Intel DG31PR mobo with nVidia 460GTX Intel Core 2 Duo 3GB RAM DDR2 Was working fine. Changed casing today and 1. no display shown 2. mobo gives 4 beeps and reboots, goes back to...
Points to a mobo problem.
However, it could be a short, caused by an unseen standoff pillar making contact with the board.
I would first of all, remove the board, place it on an A.S surface and connect it to a monitor, with 1 stick of ram, No hard drive and no CD rom attached. Use a makeshift power switch to trigger the power on the Fpanel header, or carefully touch the Power pins with a screwdriver to boot it.
If that fails to work, check the board for burns, blowing capacitors and damage, especially underneath
If it does work, replace each component in turn, examine the case to see you are not placing the board on a standoff pillar that will not be taking a screw
Jan 07, 2011 | Intel DG31PR Motherboard
HP Pavilion dv2700 & Artifacting
`use a lap cooler and under clock ur gpu when not in use
Jul 27, 2009 | Computers & Internet
Hi I have a Toshiba satellite laptop M30-127 when I boot up the screen breaks up into many colored lines and the resolution seemed to go I'm told by some Toshiba service technicians that there is a problem...
This may or may not be of some help. http://www.laptopka.com/2006/04/12/remove-replace-video-board/
Usually with laptops you have to replace the mobo but looks like there may be a possibility (slim one) that the card can be replaced, however I could not find anything as far as parts to get to replace just the video card so its looking more and more like the whole mobo would need to be replaced.
Jul 14, 2009 | Toshiba Satellite A215-S4747 Notebook
No video display
hello mr,carrera :) ...
i think u have only two choices u have to do :
1: you disconnect the power cable from you PSU , then reset the BIOS using the jumper pre-installed on your board , check the manual for this " Clear CMOS " ,,
then try again , if not then
2: u will have to replace your bios with an updated one of the exact motherboard model , you can do this easily cause Biostar have the socket of Bios ,not mounted in the motherboard ,,,
so, i am pretty sure that its a bios issue , like 95% ,,,,
the 5% u don't wanna know it ,,,,( Bad PSU might affected the power ct. of your Board :( ,,,, but try Bios 1st....
May 15, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
Bad video board? Trying to figure out is card is bad or if it's drivers.
I agree, it does sound like it is on its last leg. Keep the settings on low and run it til it dies!
Apr 22, 2009 | HP Pavilion Media Center M1090n (PC100A)...
Colored dotted lines across the screen
If you understand the components of a computer pretty well, open the case and remove and reseat the graphics card into the slot.
Does it seem to only do it after so long, for example turn the computer of for a few hours, and it wont happen when its first turned on, but then a few moments later it starts after its warmed up?
If this does not resolve the issue, you may be experiencing graphic artifacts which can occur when a gpu is overheating due to a poor cooler. Check to make sure the heatsink is touching the gpu.
Artifacts: http://www.playtool.com/pages/artifacts/badgpu.jpg
Apr 20, 2009 | XFX GeForce 6200 Graphic Card
Plasma Philips (42PF9630A) Top Half Has Artifacts
There is nothing you can do in the menu but a tech would need to be contacted. Bring up the menu and if the problem is not there replace the small signalbaord. If it is replace the Y upper board.
Aug 18, 2008 | Philips 42PF9630A 42 in. Plasma Television
Video card issues: Artifacting
Make sure the drivers have been updated as well.
Here is a link to get them
See if your video game software needs to be upgraded.
Make sure no programs are running in the background.
How much memory does your computer have?
Jul 15, 2008 | HIS H387X2F1GNP RADEON HD 3870 X2 HDMI 1GB...
Dell inspiron 9200 boot problem
uslay the mobo on these u can replce just the video dell has online guide to open it right up easy shows u how to pull it out its not to bad but u will need a t8 star tool sears u can buy one usally when screen goes out bad mobo o these ok they get hot best to open it up clean all dust out re greese the heat sinks on cpu and video but usally power chips on mobo go bad on these ones sell it on ebay like i did
Jan 14, 2008 | Dell Inspiron 9200 Notebook
Open Questions:
Computers & Internet Logo
57 people viewed this question
Ekse
Alun Cox
