Unable to capture analog video using pinnacle 710-usb and studio 11
    Guru:
  • 377 Answers
Hi dear
maybe you can use a mpeg card or TV-Tunner card to capture your analog mode
and use Ulead video studio ver. 7 , 8 or 9 for analog software
oke dear
cropp
Posted on Mar 18, 2008
SOURCE:
Sony CCD-TRV438E Hi-8 Analog Camcorder i need driver to connect with my pc
You need to buy a TV card which comes with audio /video composite sockets. these are female RCA or phono sockets which are also found on your camera.TV cards come with their own software to be able to capture pictures from your Hi 8 Camcorder using the av cables like the ones you use from your DVD to your TV set. There are other cards which carry the av sockets and come with video capture software. These cards are usually PCI cards which are fitted into your PCI slot in your PC motherboard. One other software that comes with such a card is Pinnacle Studio. Its called the Pinnacle AV/DV pci capture card. The one I use is just a DC 10 which works with Studios version 8. Please try any of these cards for your video capture
Oct 28, 2011 | Sony CCD-TRV438E Hi-8 Analog Camcorder
I have bought a cannon XH-A1 HDV camera but find i cannot capture scenes using Pinnacle Studio plus v9 could you please advise me on what is required, may be studio 11 plus for windows XP will solve this?
Hi there
Pinnacle Studio Plus V.9 can only be used for editing DV and not HDV however Pinnacle Studio Plus V.11 can be used to edit both DV and HDV.
Please remember to put a good rating on this post.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 27, 2008 | Canon XH-A1 High Definition Mini DV...
Capture working from camera but not from movie box VCR analoge input
Check the Image source if well shielded. Weak or broken shield in cable will affect the video-sound quality. Try different cable and analog video source. Once you ensure that nothing is wrong at input side. Uninstall-Reinstall the driver and the accompanied software also update driver and the software from Pinnacles support website.
Here is the link for the latest downloads and updates
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+Family/Studio+version+9+Support/Contact/Contact+Support/
Good Luck
Jan 21, 2008 | Pinnacle Studio MovieBox DV 9 (210100349)...
I have a pinnacle moviebox 510-usb. The specification contains, you can streaming from analog secam source, but in importer section i can't see any video after switched secam mode, while the vcr play...
Be sure that your MovieBox capture device is selected under Studio's "Setup/Capture Source" selection (assuming you're capturing analog). If the MovieBox doesn't show up in that selection window, there could be a problem with the device.
Additionally, check in the Diskometer left-hand panel (this is found at the center of the bottom of the screen) and see that the correct input port value (either composite or s-video) is selected.
If you're capturing digital, then you'll have to use a Firewire connection to the MovieBox device.
Hope that's helpful.
Dec 31, 2010 | Pinnacle Studio MovieBox Plus - Video...
I have the Moviebox USB (the Porche design) I'm running Studio 14 on windows 7, but it wont detect my moviebox? The pc tels me it works fine, but the Studio wont detect it. I have tryed the hardwaredrivers...
I have the same problem. If you have an earlier version of Studio (i.e.; Studio 12) with which Moviebox USB works, then retain that version for capture. For all else, use Studio 14 by retrieving your captured footage from your hard drive.
Aug 20, 2010 | Pinnacle Studio MovieBox USB Video Capture
I'm capturing video from a Sony DCR-TRV27 Mini DV Digital Handycam. The original tape is crystal clear with great color on our 1080 flat screen. The captured video is fuzzy, color washed out, a serious...
Welcome to Fixya,
What is the Pinnacle capture device when you try to capture the video? Is that 500-usb or 710 usb? What is the Pinnacle program did you used? Need to know it before we proceed
Aug 10, 2010 | Pinnacle Dazzle DVD Recorder
Does moviebox usb work with studio 14 and vista? I can't get my camera to show as an import device when connected to the movie box.
This is the latest hardware device that can used for Studio 14.
Check the list.
USB based
  • 710-USB
  • 510-USB
  • 700-USB
  • 500-USB
  • MovieBox Deluxe
  • DVC-103
  • DVC-107
  • DVC-100
  • DVC-90
  • DVC-130 (There are no 64-bit drivers for this product.)
  • DVC-170 (There are no 64-bit drivers for this product.)
PCI based
  • 700-PCI (a.k.a. Pinnacle Studio Deluxe 2)
  • 500-PCI (a.k.a. Pinnacle AV/DV)
  • Any 1394 cards.
Are you using vista 32 or 64 bit system? If Vista 64 bit there is no driver for your device and the only available is 32 bit only. Aside from that you can check also the video cable you were trying to used. If firewire under import/capture tab of Studio 14 you need to select the name of your camcorder or dv camcorder. Check that out and try.
Dec 07, 2009 | Pinnacle Studio MovieBox USB Video Capture
Computer not recognising VCR- what plug should i use?
You need a TV tuner card to be able to read both audio-video signal, else how are you going to covert analog to digital. The VCR gives out analog output.
........sodeep
May 08, 2009 | Pinnacle Studio MovieBox DV 9 (210100349)...
Pinnacle MovieBox USB Power
You can use a universal one but it has to be 3.3 Volts at 3 AMPS and the tip of the plug must be positive. If you have a radio shack by you they should be able to get you the correct adaptor.
Thanks,
Mark
Nov 01, 2007 | Pinnacle Studio MovieBox USB Video Capture
Open Questions:
Computers & Internet Logo
180 people viewed this question
Ekse
Alun Cox
