Question about Admiral AW22 Top Load Washer
Admiral Top Load Washing Machine
My agitator has come off the spindle. I thought it just snaps back on, but when loaded with clothes, it pushes it back up and off!
I had this recent, as well. The plastic grooves are wearing down, so there's nothing to hold it together with. I got some gorilla glue, and put the agitator back on the metal part that comes out of the motor. I let it set over night to dry. It's worked since I did it, and the agitator stays down...
Posted on Mar 24, 2008
SOURCE:
During filling reaches fL before finished filling and stops
Not sure if this was explained to u but these washers do not fill like the old top loads did... the machine uses very little water, the clothes are rolled over and over through the water as it cascades down and up through the agitator. If you look at the agitator you'll notice it does not have an elongated spindle, it's not required. Although the machine doesn't fill your clothes will be fully washed, this design was developed to conserve water...
Aug 19, 2013 | Kenmore Oasis Agitator 4.5 cu. ft....
Will not agitate
check the module that controls the agitation of the motor. It is found in the control panel and if it fails the motor has no agitation action. have a washing machine check it out.
Jul 14, 2013 | Admiral AW22 Top Load Washer
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    How do you remove the aggitater
    1- First you must determine the brand of washing machine you have. 2- To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
  • Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts. 3-Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
  • Read more: How to Remove an Agitator From a Washing Machine ' eHow.com http://www.ehow.com/how_4620771_remove-agitator-washing-machine.html#ixzz1IhUKY7OQ
    Apr 06, 2011 | GE WBSR3140DW Top Load Washer
    Admiral washer will agitate but will not spin dry
    Problems with a washing machine not spinning or not draining are often interrelated..
    If you are having a problem with your top load washer then check out thistip...
    Washing Machine does not Pump or Spin
    If you are having problems with your front load washing machine then checkoutthis tip...
    Front Load Washing machine not draining and or not spinning
    heatman101
    Sep 19, 2010 | Admiral AW22 Top Load Washer
    Load squeal when it in the agitation cycle.
    Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
    for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
    Dec 29, 2008 | Admiral AW22 Top Load Washer
    Admiral Top load washer won't agitate and squeals
    Sounds like the gearbox, unfortunatly this is sealed and is cheaper to replace the machine, presume the machine is quite old.
    Jun 28, 2008 | Admiral AW22 Top Load Washer
    Spining
    More than likely a loose agitator, remove the cap in the centre of the spindle where you put your conditioner by pulling, inside deep down you will see a 17mm bolt, tighten using a socket and long extension, you should remove the agitator to see if there is any damage or wear to the agitator plastic splines before securing fully. Simply undo the 17mm bolt and lift the whole agitator out in one.
    Mar 23, 2008 | Admiral AW22 Top Load Washer
    Admiral Washing Machine not spinning
    y Admiral washing Machine modle # lnc6760b71 will fill with water and agitate. But when it come time for the spin cycle it wont spin. I can hear the motor making noise. and now stop and it does not work, does not smell to burned What should I do??
    Jan 06, 2008 | Admiral AW22 Top Load Washer
    Admiral AW22 Top Load Washer Logo
    95 people viewed this question
    Top Admiral Washing Machines Experts
    jimorris77
    Gerry Harvey
    Gerry Harvey
    Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
