Question about Akai LCT2662 Television
AKAI LCT2662 I have a 26 inch AKAI LCT2662 and it won't turn on, but a little red light will flash on the bottom right of the TV. Do you know what could be wrong?
  • 2 more comments
  • Anonymous Jul 18, 2008
    I had the same problem. When I looked at the power supply, I could tell by the rounded tops of the caps, that was the problem. I replace 19 caps in the power supply 4) 3300uf/35v, 8) 2200uf/25v, 6) 1000uf/10v, 1) 1000uf/16v
    I purchased them by mail from All Electronics. Now my TV works great.
  • junwilbr Jul 26, 2008
    I have the same problem and another one I live in Gainesville, Fl and there is no one to fixit
  • oggcouple May 11, 2010
    Generally speaking, should I assume that the capacitors that are slightly rounded on top to be bad and the ones that are flat good? Thanks for the help. Jan
  • junwilbr May 11, 2010
    how and where can i get the power supply for the aki lct 2662
    Problem Solver:
  • 26 Answers
I can repair your power supply for you. Please email me at tracy_tangen@hotmail.com. Thanks.
Posted on Jan 22, 2010
Thanks for the advice, premtech. My LCT 2662 finally died from power supply problems after about two and a half years of use (it started giving us problems about six months ago). After reading the fixya.com recommendations to replace the capacitors on the power board, I decided to give it a try. I took the back off and was grateful to find the power board to be easily accessible. It was immediately apparent that several of the 2200uf capacitors had all bled out. There was crusty brown dielectric everywhere! The 1000uf appeared to be in good shape, but I ordered a new set of those anyway, along with the 2200uf/25v caps as well. I replaced all of the 2200uf caps first, since they were pretty much all fried, and tried the set out. The red power light came on, but when turning the unit on, I would just get a momentary flicker of the main screen, then nothing. After poking around the power board some more, I noticed that the four 3300uf caps also look to have melted out. So it was back to the Jameco website to order more parts. After replacing those four caps, the tv mercifully came back to life and has worked like new for about an hour now. I did not have to replace any of the 1000uf caps, but who knows how long the original ones will last. Oh well, I have to parts and know how to fix them if they do burn out. Thanks to all those who suggested the fixes. You sure know your stuff!
Dennis W.
Posted on May 04, 2008
  • 62 Answers
The power supply is not available for this unit - call 800-726-4005. request an exchange because the parts are not available. Parts are supposed to be avail;able by law fow 5 years.
Posted on Mar 29, 2008
  • 934 Answers
Power supply most likely... It's a common problem with this particular model and we've seen quite a number of them for exactly what you're describing.
You need to replace 19 caps in the power supply 4) 3300uf/35v, 8) 2200uf/25v, 6) 1000uf/10v, 1) 1000uf/16v and you can go a little higher in the voltage of each cap for greater reliability.
It's best to have an ESR meter also and test the remaining caps as well.
Bill
Posted on Mar 27, 2008
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
We have the Akai 52"
Replace the lamp, after you replace the lamp reset the lamp hour meter good day and best regards.
Aug 28, 2011 | Akai PT5492S 54" Rear Projection...
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
We have had our 27 Inch Akai LCT2785TA for almost 2 years, just today we cannont get it to turn on the red light will just flash when we try to turn it on. Can you give me an explanation and a fix for this...
We have had our 27 Inch Akai LCT2785TA for almost 2 years, just today we cannont get it to turn on the red light will just flash when we try to turn it on. Can you give me an explanation and a fix for this problem
Sep 08, 2009 | Akai LCT2785TA 27 in. LCD Television
Getting Akai model PDP4273M plasma to accept a new remote
Hold The Clear Tv buttom until all 4 light flash red , then press code search at the bottom right , then the up arrow until ur tv goes off and finally record , after that u only need to press the red tv buttom to open it or close , If it doesnt open it back its because u press the up arrow after the tv was shut off so do the same thing be using the down arrow .
Mar 19, 2009 | Akai PDP4273M Television
Tv wont turn on
Hi
Please go to ebay and buy your power supply board:
AKAI LCT3785TA POWER SUPPLY BOARD MLT386X
Oct 02, 2008 | Akai LCT3785TA 37 in. LCD HDTV
Akai PT5598HDX/SMS won't turn on
Just a thaught, I could be wrong, maybe a problem with the power button on the remote ? It might shut the TV off, and when you do keep pressing the remote button, the red light on the TV will keep flashing like that also. Ive seen this prob on a few other blogs, so seems to be pretty common. I know I like to keep the remote pointed at the TV all the time, maybe try pointing it away for a while, just to see.
Dec 30, 2007 | Akai PT5598HD 55" Rear Projection...
Akai LCT2716 Flat Panel TV
I HAVE A RED BLINKING LIGHT ON MY TV ANY IDEA'S HOW TO FIX?
Sep 13, 2007 | Akai LCT2716 27 in. LCD Television
Our tv will not turn on
Our AKAI was just 14 months old. A few days ago, it died also. Blank screen, no sound, but the timer light will flash on a couple of times when you try to power it up. It even sounds like it wants to turn on. I paid a tech to come to my house $65 and it turns out to be the power supply $385. I checked other chat boards and many people are having this same problem with their AKAI 42" (PT4298HD) televsion. A real piece of junk this model! Sorry for the bad news!
Sep 10, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai LCT2662 Television Logo
400 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
