Xerox 8400 my printhead not in correct position
  • 552 Answers
Http://www.office.xerox.com/userdoc/P8400/8400_Web/partslist/
Here is a xerox website with detail drawings of your printer model.
Also, tips available.
Posted on Mar 18, 2008
    Guru:
  • 1,894 Answers
In order to apply the fix, you must gain access to the right side of the printer as you are facing it. Also, the top of the printer needs removed so that you can gain access to the printhead and the wiper.
remove two screws from the back (note which screw came from which side as they are of different lengths),then locate and slightly bent the plastic release tab on each of the side panels and so it is able to easily remove the panels. The top portions of the printer can be removed and coaxed out rather easily.
see the printhead tilted back with the wiper assembly inbetween it and the frame. While lifting the printhead off of the wiper, slowly rotate the white gears on the top right portion of the printer so that the wiper started going down.
The printhead then returned to its fully rested state and the printer has never worked so well!
  • dewan nafees ahmed Mar 18, 2008
    sorry....
    after doing it will work...try it n reply
  • 4,889 Answers
Ok.. did you get this error message or did you just find something fishy..?
SOURCE:
I have a xerox phaser 8400 printer that will not do anything, just reads "fault 37,004.40:32046" what can I do? Thank-you
The 37,004.40 error means that the ink reservoir is not heating up correctly. Make sure the printer is plugged in directly into the wall and not on a power strip and cycle the power to the machine (turn it off and back on). If the problem continues, you probably have a bad printhead which you have to replace. For the 8400 the part number is 650-4303-00. Iteminc.com has that part in stock and ships same day. Here is a video that shows you how to replace the printhead. Hope this helps and thanks for using FixYa.
Aug 16, 2011 | Xerox Phaser 8400 Laser Printer
Xerox on a 8400 faults code 37004 403B25998 what does it mean
37,004 is a printhead error, specifically that a Reservoir heater isn't drawing power from the power supply.
The printhead 650-4303-00 is expensive, unfortunately.
Whit
Item, Inc.
May 06, 2010 | Xerox Phaser 8400 Laser Printer
Xerox phasor 8400 - fault 37,004,40:157517"
Hi I can gave you some error codes but this all I can do hope it be of help to you.
8,009.4x:CAP_FAULT_MP_NO_ CLUTCH_STALL:
  • The media path motor has stalled while moving without the clutch engaged.
33,001.4x - TM_DEV_FAULT_MPT_WIDTH_VALUE_TOO_LOW
  • Tray 1 status:
1. Check the wiring and connectors from the front door to the I/O board.
2. Run the Test Tray 1 Width Sensors.
3. If the test fails replace the front door.
4. Replace the I/O board.
08.055.44:
  • The media path drive module has stalled while engaging the head tilt.
37,008.44:
  • The Preheat preheater is not drawing the expected power from the supply.
Run the Preheat Heater test, check the wiring. If test fails and no apparently problem is evident, replace the preheater.
05,002.42:
  • Problems with the Y-axis. It could be the belt,motor or the drum.
7,008.4x: PM_FAULT_HEADTILT_NOT_ ENGAGED
  • The printhead tilt is not engaged, so it didn't tilt back properly or the printhead is stuck in the tilted position by the tilt lock arms. The process motor gear train getting out of sync can also cause this error.
1. Try rebooting the printer.
2. Check for an obstruction or damage in the process gearbox.
3. Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox
assembly.
4. Run the Tilt Axis Drive test to test the headtilt.
5. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
6. Run the Wiper Axis Drive test.
7. Replace the exit assembly.
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
  • The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox being out of sync can also cause this error.
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive module shaft are at home position.
6. Verify the headtilt gear will engage, see the home positioning procedure on page. You can manually engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper drive system.
All The Best: Pineworks
Jan 05, 2010 | Xerox Phaser 8400 Laser Printer
Our printer is showing fault reference: 07.010.43:46041. Can you identify the problem and offer help? Robert Savage
7,010.43: The Printhead is stuck in the tilted position, or is not able to tilt
forward to the print position, due to problems.
  1. Try to reboot. still nothing
  2. do the printhead restraints rotate correctly? They are black plastic peaces that pull the print head back to it's home possition. Replace the print head restraits.
make sure no ink is spilled in the printhead area that could also be causing the jam. Clean around the print head area.
also make sure that the printhead is not stuck to the wiper blade. if it is do the following:
Start the printer in diagnostics mode and run idiags test Exercise Heater - toggle Printhead heaters to soften the ink. Manual separate the wiper and Printhead. Set them in their home positions.
well good luck.
Nov 19, 2009 | Xerox Phaser 8400 Laser Printer
When I turn on my Phaser 8400 I get an error message of 07,008.41:4825. What the problem. Thanks for your help.
7,008.4x: head tilt not engaged.
2.make sure there is no ink melted under the printhead which can make it dificult for the printhead to work properly..
3. make sure that the printhead restraints are not broken.
4. Check for an obstruction or damage in the process gearbox.
Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox assembly.
5. Run the Tilt Axis Drive test to test the headtilt.
6. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
7. Run the Wiper Axis Drive test.
8. Replace the exit assembly.
good luck!
Nov 13, 2009 | Xerox Phaser 8400 Laser Printer
Message reads error Press I. code 07.010.43:94437, can you please tell where the problem occurs.
1 Reboot the printer.
Did this correct the problem?
2.Do the Printhead Restraints rotate
correctly? if no. then Repair or
replace the
Printhead
Restraints.
3.
Has ink spilled ink around the Printhead
that prevents the Printhead from moving
to its center position? You should be able
to push the Printhead right to left. Make sure the printhead area is cleaned.
4.Is the Printhead stuck to the Wiper Blade?
Start the printer in diagnostics mode and run diags test Exercise Heater - toggle Printhead heaters to soften the ink. Manual separate the wiper and Printhead. Set them in their home positions.
5. Does the X-Axis Motor drive the Printhead
to its center position (so it can tilt forward)? if not
Troubleshoot
the X-Axis
drive.
Well hope this helps.
Nov 09, 2009 | Xerox Phaser 8400 Laser Printer
Xerox 8400 error 07.010.43:52882
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward to the print position, due to problems.
Do the printhead lock arms rotate correctly.
Has ink spilled ink around the printhead that prevents the printhead from moving to its center position? You should be able to manually push the printhead right to left.
Does the X-axis motor drive the printhead to it’s center position (so it can tilt forward)?
1. Check the process gearbox for obstructions
or damaged.
2. Ensure the gears are correctly aligned and
homed.
3. Verify the process shaft and drive module
shaft are at their home positions.
Has ink spilled on the head tilt gear on its drive train (near left side of the printhead).
Aug 30, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 first page blurry
  • Tray 1 status:
08.055.44:
37,008.44:
05,002.42:
assembly.
Aug 26, 2009 | Xerox Phaser 8400 Laser Printer
8400 error 07.010.43:125364
Printer was caught mid-stride. Need to pop the printhead loose from the wiper and re-home the mechanism to get it rolling again.
Apr 15, 2009 | Xerox Phaser 8400 Laser Printer
Xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Jan 19, 2008 | Xerox Phaser 8400 Laser Printer
Open Questions:
Computers & Internet Logo
29 people viewed this question
Ekse
Alun Cox
