Question about Acer AL1716Bbd 17" LCD Monitor
  • mslucky24 Oct 30, 2008
    all of a sudden when i turned on my computer, the monitor hesitated to come on, then it did. the next day the same thing happened exactly. then after that the green "on" light would come on, but the monitor never came on again. i wonder if this is fixable.
    Thanks. Bev
  • Anonymous Mar 25, 2014
    it has generic pnp monitor and my monitor will not stop with the flashing
  • 138 Answers
I used to repair LCD monitor from Dell. It works for me. You might be using these following steps to examine what wrong with your monitor. After you turned PC on and monitor stopped working or went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image (Start menu), there will be a minor problem. This is because of CCFL lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 18, 2008
  • 293 Answers
SOURCE: Acer AL1716 Blank screen & blinking green power LED
You've got a busted backlight inverter... Need to replaced a new one...
Posted on Dec 18, 2008
  • 1684 Answers
SOURCE: Acer AL1716 A Monitor does not start
The problem on your monitor is a bad power supply. Because of heat buildup in LCD monitors parts called capacitors overheat and blow out. You can go to our web site at: and see what to look for. If you open your monitor and see blown capacitors that look like the pictures on our site then replace the bad ones and you should be back going. Email me if you have additional questions or if you need to get the capacitors, we carry them in stock.
I hope this helps, if so please rate my solution.
Corporate Computer
Posted on Aug 27, 2009
  • 24 Answers
SOURCE: acer al1716 dont work
Sounds like the inverter to me.
Posted on Sep 17, 2009
  • 2841 Answers
Push the button on the front that says menu. Within that menu you will find the brightness control. Use the other buttons to move through the different menu items until you get to Brightness. Once there push the menu button again and then adjust the brightness with the other buttons.
Posted on Nov 27, 2009
  • 11361 Answers
SOURCE: acer al1716 monitor input not supported
You get the message because the game try to run at the PC video resolution that you monitor cannot display/support. You need to run your game at native resolution of the monitor.
Posted on Mar 25, 2010
I have an acer al1716 monitor and since 2 weeks ago on the screen apears a box with the " input not suppported" message, then the pc shuts down. i may have changed the resolution settings and now...
the video settings on your computer has changed to a setting that the monitor doesn't like! try entering your computer in safe mod and change the setting to a max of 1024x768. however, if your video card has a dual output and you have 2 monitors connected at the same time then this is your problem. make sure that the 17" lcd is monitor 1 and the other monitor #2. one of the monitors is set higher the the 17" lcd and when it is not connected the computer may think this the setting for the 17" lcd and not the other monitor which may be hdmi or 1900x1080 which the 17" cannot read this it is out of range!
Aug 24, 2011 | Acer AL1716 17" LCD Monitor
3 horizontal lines at top of lcd Acer AL1716.Can it fix. Is it lcd driver or mother board problem?
in order to diagnose whether the driver or the LCD you should try to plug your LCD into other Computer, if the line still appears then the problem is the LCD, you might have a dead pixel
Apr 23, 2011 | Acer AL1716 17" LCD Monitor
What is the screen resolution for acer al1716 monitor
Hold the power button down for at least 10 seconds till the light goes out, then turn it on and the problem is gone.
May 16, 2010 | Acer AL1716 17" LCD Monitor
Will an Acer AL1716 monitor work with a Dell 4600? Do I need a monitor card?
It has video card already, just make sure the video card driver is correct. Mkae sure to set the PC video resolution to the native resolution of this Acer, which is 1280 x 1024 @60Hz.
May 10, 2010 | Acer AL1716 17" LCD Monitor
There is no indication of power to the monitor. I
You need to check the caps in the power supply section, please see my pictures here so you know what to look for inside.
Feb 19, 2010 | Acer AL1716 17" LCD Monitor
Acer al1716 dont work
When the LCD monitor display flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
Sep 03, 2009 | Acer AL1716 17" LCD Monitor
My monitor is new .. the screen stays black and the power button flashes green ... how do i fix this ????
I have acer al1716 LCD and whan the computer is turn on, the lcd led turn green but the lcd is showing black, what i can do?
thank you!
Apr 16, 2009 | Acer AL1716 17" LCD Monitor
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
1. Unplug the AC power cord to make sure the power is off.
turn the monitor upside down, you need 2 people for this.
2. Pull the 4 hooks on bottom side of the base and hold.
3. Separate the monitor and base.
Nov 05, 2008 | Acer AL1716 17" LCD Monitor
Acer AL1716Bbd 17" LCD Monitor Logo
514 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
