Question about HP PSC 1315 All-In-One InkJet Printer
Canon IP3300 my printer keeps feeding in mutiple pages, up to a dozen at once, when I'm trying to print a single page. is it time for a new printer?
  • SteveCartman Mar 31, 2008
    Feeding many pages at once
  • 20 Answers
There is a problem with the separation roller or paper guide not functioning causing the paper pick up without separation.
Posted on Apr 18, 2008
    Problem Solver:
  • 17 Answers
Clean you print que it prints all the pages because the print button was pressed several times so for to empty the print que unplug itwait 30 seconds then restart the printer if you press print more than once all the pages will print when the printer is turned on safety measure
Posted on Apr 14, 2008
NEED TO PRINT A TEST PAGE MANUALLY FOR CANON PIXMA IP3000
Click on Start - Printers and faxes - right click on your printer - Click Properties - then click on Print test Page.
Mar 19, 2013 | Canon PIXMA iP3300 InkJet Photo Printer
Need to print a test page
Click Start - Printers and Faxes - right click on the printer - click Properties - click Print Test page.
My HP C6380 won't print multiple copies of a page even though I select how many copies I want of the page . I have to keep printing each page individually which is very time consuming.
what is he OS ?........what connection USB/wireless ?..........From what application you are printing? ..........have you checked the printer printing properties and ticked of the collate check box where you have selected mutiple pages ?.....
Jul 15, 2010 | HP Photosmart C6380 All-In-One InkJet...
My ip4300 keeps printing the same page over and over again. There's nothing in the print Q, but no matter what new job I send to the printer it prints the same old page. Is there a way to reset the printer...
Have you rebooted your computer? The printer's memory is very limited -- certainly not enough to hold an entire page. Your computer feeds the printer a line at a time, so it would seem that your computer's print spooler is 'stuck' on that print job. Try shutting the computer down completely, then restarting and see if that print job clears out.
Mar 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
The page prints to a small version in top left hand corner. everything is set to A4. Have tried all settings Have tried paper feed from back and front. Unable to get it to print a full size A4 page even...
Make sure on the Page Setup tab that the Page Layout says 'Normal-size' and not 'Poster' (poster tries to place four documents on a single printed sheet). If this is not the problem, try uninstalling and reinstalling the printer driver.
Feb 10, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Canon ip3300 paper feed not working properly
There is a small switch on the bottom left on the front of the printer that was selecting envelope feed instead of paper feed. Changing this fixed the problem.
Jan 14, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
More than one paper at a time
Are you saying that the printer pulls in too much paper at a time, or that it's actually printing on more than one page, even if you only want to do a single page? If it's pulling in too many pages, try fanning the paper. At times, especially in low humidity conditions, paper will tend to stick together and then several sheets get pulled into the printer. Fanning will often relieve the symptoms. Also make sure that the feed roller is clean. Use a cloth with some alcohol on it and rub the tire all the way around or as much as possible. See if that works.
Jan 28, 2009 | Canon BubbleJet i550 InkJet Printer
VERTICAL PRINT LINES
Check the front paper exit rollers for fit and alignment also the paper deck guides close to the planten area, if the printer is dropping print vertically down one side of the page, this can be caused by debris or anything that lifts the caridge assy the slightest bit, also check the print head seating and ribbin cable for proper alignment
Apr 04, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Canon Pixma iP3300 printer
Problem solved. press and hold the RESUME button on the printer (just below the power button) until the power button flashes green three times. Release the RESUME button and the paper roller will automatically clean itself. Do this twice and it should work perfectly.
Feb 20, 2008 | Canon PIXMA iP3300 Printer
Canon PIXMA iP3300 Won't Work!
My first suggection is to return it to the store for a full replacement with you original receipt. No way should a printer do this just out of its box. The more you fiddle with it, the less likely to be able to replace it (and the longer you leave it to. If you leave it too long, you will have to have it repaired under warranty. You can try uninstalling it by following correct pc directions at remove programs menu. Then, unplug it after turing it off. Replug it, reinstall it. Try printing now. If still no good, repeat the whole process but this time, do not reinstall with original disc. Make a copy and reinstall the printer with the copy. Noe try printing again. If no luck, return it to store in as original condition as you can manage with all softwares and mauals and your receipt and demand a replacement, Under fair trading they cannot refuse.
Sep 01, 2007 | OEM Systems PIXMA iP3300 Photo Printer
HP PSC 1315 All-In-One InkJet Printer Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
