52" RCA need to fix cracked outer screen on my 52 inch rca tv.where can i buy one,and is it hard to fix,can i fix it myself
  • hickeyrick Mar 19, 2008
    the model # is R52WH74,is there somewhere that sells the outer screen? I cant seem to find anything online yet
  • 4,234 Answers
The availability will depend upon the model number of the set. Changing it should not be a major problem. I would suggest that you search the web for the service manual that will show you the correct way to replace the screen. The cost of the manual is minimum ($10-$15).
Dan
Posted on Mar 18, 2008
Hi RCA 52 inch part numbers P52937SG
Tries this website for convergence ICS.Must know how to solder?Tv Repair World.com,Ebay.com.
Oct 15, 2009 | RCA P52937 52" Rear Projection Television
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
The screen on our 52 inch TV needs cleaning-inside and out
The outer screen is a protective screen. it is just glorified plexiglass. just use a soft cloth slightly damp.
Apr 09, 2009 | RCA D52W19 52" Rear Projection Television
Picture is warped. rca 52 inch model p52929
This is hte beginning of a convergence problem. If you can solder, try resoldering the pins on the convergence ICs. These are large black ICs attached to a heat sink and will be marked STKxxx. If that fails to resolve the problem, replace the ICs.
Keep us posted.
Dan
Aug 25, 2008 | RCA P52929 52" Rear Projection Television
RCA p56926 replacement screen
you cant, the screens for that model are no longer available and even a used scree assembly will be over 200. if you could find a new one they would be about 4 to 500.00
May 25, 2008 | RCA P52926 52" Rear Projection Television
Replacement of outer screen for a Toshiba TP50H60 projection tv
A frosted sheet of plexiglas works well. I put a plexiglass screen on my own 62 inch projection TV. It must be frosted to received the image being projected.
Jan 03, 2008 | RCA R52WM24 52" HDTV Projection Television
CRACKED SCREEN
the outer screen on these units easly replaced. RCA #258797 their called supersheilds.. rca charges about 70 dollars for the item...If it is just that i have seen people just use a clear sheet of plexi. removeing the screens requires removein several torx 20 screw around the outer and remove the frame.. then the clear peice of plexi is attache with serval brackets.
Dec 25, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv screen
try, mcmelectronics, vancebaldwin.com, tritronics
Oct 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Electro Med Services...
