Question about Intel Motherboard
Packard Bell 4451 lap top will not power up.
My Packard Bell 4451 lap top will not power up. If i try to power up off the battery nothing happens. If I plug the power supply in together with the battery, the charge light flashes once, then the power light flashes once, the sequence does this all the time the power is on but pressing the start button the computer does not power up.
If I remove the battery, just using the power supply, both charge and power lights flash at the same time, pressing the start button the computer still does not power up.
I have checked the power supply and it is putting out the correct voltage.
I have the old battery and a brand new one.
If i plug the power supply in and test the terminals where the battery plugs on to, I can only get up to about 4volts max. from any of the terminals.
I have tried removing the internal battery and holding the start button to discharge the memory, but it still would not start.
The computer was working fine, the wife left it booted up one day after using it, when we came back to it all we had were the lights flashing as above and could not restart it.
Could it be the small charger pcb s/n: 2B180001 !A 0246 ? or do you think the mother board is dead?
Can you still get parts for this lap top?
Kind regards,
Danny Holland.
Check the back of the power connector to see if it is loose. I have known alot of situations were, if not carefully removed, that power connector in the can free itself from the sodder on the Mother board therefore you wont be able to charge the battery nor boot up. hope that helps
Posted on Mar 19, 2008
SOURCE:
Please can you advise me on the following ,Laptop when switched on Packard Bell logo is shown nothing happens,and screen is frozen.Lap top is not connected to internet.
Windows is not starting. That is what is happening. Try to repair it using this link: http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
If this doesn't work, try this: http://www.fixya.com/support/r4501848-when_windows_xp_start_secondary_fix
Sep 30, 2010 | Computers & Internet
My power supply for packard bell blew up due to much power,so i
The style of power supply is different from a universal power supply. A universal power supply won't fit in the slot properly.
This website has it for fairly cheap:
http://www.partstore.com/GetModel.aspx?MfgName=Sumitomo+Group&BrandName=Packard+Bell&ModelNumber=845061&Page=1&SortBy=idealitemnumber&SortDirection=desc
Apr 23, 2010 | Packard Bell (190169) Power Supply
Packard Bell easy not wont turn on
it is not charged or its battery has a loose connection
Jul 22, 2009 | Toshiba A15-S1292 Notebook
Packard Bell F9150 desktop power supply
open your cpu cover .
Then check your power led on motherbord blink or not also reattcha ll connection to motherbord.
check your smps fan is movinh when you switch on.
May be you have to change smps it is square box from with you attch power code.
Jul 17, 2009 | Computers & Internet
My packard bell easy note laptop is chargin but not switching on. I don't know what to do. On the fron of the lap top, the middle light comes one. Shines blue, looks like a battery with a flash through the...
what u have did last time is not solution for that.
please make sure first ur notebok is charged enough. then unplug it. remove the battery.
Then pls remove RAM chip , if u knws (be care ful , dont do if u dont knw) . Flush it electronically. and insert it after 5- 10 mins.
(prob u cant flush it at ur home, it needs device that clears all contents on it).
and then insert RAM . restart PC. Hope this wil work.
Let me knw if this info is helpful to u..
Jun 16, 2009 | Packard Bell Easy One Silver 2101 Notebook
Some one has given me a Packard bell easynote C 3300, ive plugged it in the power supply but all i get is a flashing orange battery light, what is happening please
try takeing out the battery and then try pluging the main power back in and see what happens. if the orange light goes away that means your battery is no good.
thanks
hope this works for you
Aug 22, 2008 | Packard Bell Computers & Internet
Packard bell lap top
Packard Bell only seem to have a european site from what I can tell. If your wife can understand the language, check out the belgium site for W3903 by clicking here and see if you go through the troubleshooter, whether they would be prepared to repair it from a non-european shipping address. If they would not, it's not likely you'll find anyone who deals with it, as Packard Bell seems to be an exclusively european brand.
May 23, 2008 | Packard Bell Easy One II 3136 Notebook
Lap top computer power problem
Screws, if overtightened or replaced with the incorrect size (i.e., too long a screw), can somtimes cause a board to short. Try taking the screws out completely and then see what happens. It's also possible your laptop may have a bad power supply as a result of the case having been taken apart or put together incompletely. If the first step doesn't work have it diagnosed by a competent repair person . Also, you may consider trying one of eBay's "laptop power" repair services postings. Some offer to replace your power supply fitting (rear plug) for about $50 plus shipping.
Sep 10, 2007 | Toshiba Satellite M35X-S111 Notebook
Intel Motherboard Logo
229 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
