Question about Mitsubishi VS-50707 50" Rear Projection Television
Power turns off and color is off when first powered up
I have tried to call a repair person for this fix, but have been told that it was a $99 fee just to diagnose and could be as much as $1000 or more to fix. This tv is not worth that much. I like this tv, but refuse to waste $1000 or more if they try to tell me it was some expensive fix when it really was just a loose connection. It sounds as if the problem i am having is fairly simple to fix. Would you have any suggestions on what I should do? Fix myself, or replace?
Thanks,
Scott
    Genius:
  • 1,153 Answers
If you know how to use a soldering iron or gun, yes you can do it. First thing to do with this set is to do a self test to find out what error code the set is giving off, if it has one. You do this by pressing the menu button with the device/input button on front of set, hold for 5 sec and then you should see the LED blinking a 2 digit sequence. Count the blinks, followed by a short pause then more blinks. this give the error code and you can go directly to that area to work on.
Posted on Mar 18, 2008
My laptop hp x360 pavilion convertible is not turning on. The AC adaptor LED button is blinking in long intervals and is white in color.
drop the battery yet, disconnect it.
the service manual shows how.
see that yet?
screen 100% black all time even with ESC key pressed, power on>
if totally dead and power pack reads 19vdc then
remove the battery.
no full service tag shown so no exact answers possible.
lots of x360 made , many.
if this scares you doing repairs get it fixed in a shop, like 99% do.
Jul 21, 2017 | HP Computers & Internet
Nordyne mobile home furnace will not ignite. I REALLY need an answer ASAP
Turn down room thermostat switch power off to unit turn power back on turn up stat see if this resets unit .
Check to see if pilot is on . check to see if you have gas to you unit if not then it could be the reg on the tank .
Oct 24, 2016 | Grilling
99 saturn sc2 will not start
if it is a stander pull the floor mats out of the driver side and try again
Mar 23, 2017 | 1993 Saturn SC2
I have gateway FPD2485w have take to repair they telling me that main circuit board is bad very cost prohibit to fix. if the monitor turn off it will not come back on wait for some times it will...
what they told you is correct, the power board is failing. but the board can be repaired most often verry easily it is a common problem with gateway. i have repaired several of the 21" gateway monitors. I would be glad to do the repair for you.for a small fee.
Dec 05, 2009 | Gateway FPD2275W LCD Monitor
Power switch doesnt turn on machine
re check the computer is plugged in, and see if u can reset the circiut breaker on the power supply, the re try tuning the computer power switch button on. if it still wont turn on then take it to a repair facility for repair and explain to them EXACTLY , How I told you this, and have them check the computer.
Nov 27, 2009 | E-Machines eMachines Desktop PC
TV doesn't come on 99% of the time.
Sounds like capacitors on the power supply have gone bad. There may be some that have domed,bulged or vented, on occasion they will also dry out, due to the heat of the panel. The damaged one you can see and the dry ones will have to be tested. Worst case will be if the board is bad and has to be replaced. Cost of repair can range from $150 and up depending on the repair shop fees and if the board has to be replaced.
Sep 04, 2009 | iLO LCT32HA36 Television
First convergence problems, not won't turn on
The problem is the Convergence circuit and the reason it does not power up is that one or two of the 5a pico fuses have opened when the Convergence IC failed. It is either going to be a pair of STK392-570's or a single IC STK393-110. That is as long as this set is a Mitsubishi made in the last 7 to 9 years.
I would estimate the cost to repair 280.00 plus service call fee if any, plus tax on parts.
Let the Tech check it out. If if it cost less than 400.00 to repair, it may well be worth taking the chance.
Jun 09, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Hitachi 55FX20B 55 in. Rear Projection - no picture or sound
TV always has high voltage shock risk while repair. As you said you are not familiar with TV repair so better to handle repair person this issue.
Oct 01, 2008 | Hitachi 55FX20B 55" Rear Projection...
No power and lens will not come out
Your lens mechanism is jammed or off its "track" you need to get it realigned and lubricated w/a safe lube, like a white grease. You can try and gently "help" it out while it is trying to do this mechanically and if you hear a little ckick, then it may have realigned itself. Some have used compressed air to blow out any crud in there. Try these or take it to a camera shop. maybe they can help instead of sending it back for service as there is usually a fixed fee for ANY repair, big or small and usually eclipses the cost of a replacement camera, or very close to it.
Dec 28, 2007 | Canon PowerShot S3 IS Digital Camera
TV just flashes different colors
You have entered a diagnostic colour test. With the TV powered on, hold the 'Menu' & 'Enter' together, then press the power button. Problem resolved
Jun 25, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
Mitsubishi VS-50707 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
