Question about Mitac Mio 168 Pocket PC
Unlock my pc
Have`nt used my pc for a while and its started up locked and the screen frozen
cant open anything up
  • 1 more comment
  • Anonymous Aug 03, 2008
    dell insprion 630 laptop, completely frozen, cannot shut down, just hourglass shows on dark screen.
  • nodj Sep 09, 2008
    Same screen freeze problem.  Tried Reset, this brings up Windows Mobile screen, tap screen get "align screen" tap align points, then get "stylus" screen tap "next" and you get "pop-up menus" screen and it freezes.  There is no "next" button on the pop-up menus screen.  Removed SD card and tried OFF (switch on back) for 1 minute. Turn ON, brings up Mio DigiWalker screen woth surfboard, then Windows Mobile screen ... then same as above ... through to the "pop-up menus" screen where it freezes.
  • bell123 Oct 25, 2008
    i can`t get to tom tom, i can get to back up but not further plz help
I suppose you have tried a soft reset using the button in the small hole on the LH side & a hard reset using the rear on/off slide switch?
Posted on Apr 10, 2008
Screen locked and unable to unlock
Turn off . Press and hold POWER + ENTER button for reset menu.
Select
Factory reset with Volume Down button and press Power to reset. All data will be lost! there is an alternate method too friend
Use this method to hard reset your Samsung GT-S Galaxy mini phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Samsung GT-S5570 Galaxy mini download mode if you want to install eg. Gingerbread
Press and hold Volume DOWN + HOME + POWER ON S5570
Restart your device to clear any temporary software bugs
If you know the hard reset with buttons / keys, pls leave a comment. All comments are welcome!
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings :Privacy
:Factory data reset :Reset phone : Erase everything.
Clear storage• : Erase the credential contents from the device and reset the password
Set an unlock pattern
Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen
Settings Location and security Set screen lock : Pattern
If you forget your PIN or password, bring your device to a Samsung Service Centre to reset it.
Set an unlock PIN code
Settings Location and security :: Set screen lock : PIN
Set an unlock password
Settings Location and security :Set screen lock : Password.
You can hard reset software firmware update your Samsung GT-s Galaxy mini phone
Hope it helps u
Dec 08, 2013 | Samsung Cell Phones
Daughter locked screen. Now I cant unlock it.
As in shes put a password on screen? Otherwise if your screen is just frozen?" try holding onto top right button for a few seconds and turn it off..
Plug into PC and open iTunes
Hold top right then middle button and it will enter recovery mode, shouldn't delete anything otherwise just re add through iTunes
Mar 20, 2013 | Boost Mobile Kyocera Hydro Smartphone
My samsung s5230 is frozen i cant use the touch screen to do anything cause when i do nothing happens
The phone Freeze problem. Your phone has gotten hard-locked; it will not accept any unlock codes. This problem can only be caused by improper unlocking. Basically this happens if you or someone else has already entered 5 wrong unlock codes on your phone.
You can get the unfreeze code, NCK code and SPCK code from third party. After unfreeze your phone, you have to enter the NCK code to unlock and use it with any gsm network in the world. i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website
Jan 11, 2011 | Cell Phones
Cant unlock my ipod
What generation? What do you mean, the slide to unlock, or the screen lock? If you mean the screen lock, you should connect to iTunes, because some iPods unlock after connecting to iTunes. Otherwise you should reset it with iTunes. But then all your data will be lost. Otherwise you should try try try. You've got 10000 chances ;-) If you have an iPod Touch, you might mean the slide to unlock screen is frozen. I had that one time, after trying out spoken feedback. After that it locked the screen and the touch screen wouldn't work anymore. I couldn't do anything anymore, not unlocking, not turning off spoken feedback, not even turn off the iPod. I was lucky to find there was an update for the iPod so iTunes turned it off. Then it responded also again.
More details next time please!
Jun 22, 2010 | Apple iPod nano
My samsun pixon screen is frozen and i cant open anything
phone needs service there might be a problem with the phone internal memory
Jul 01, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
The curser is frozen in the middle of the screen. mouse doesnt work.
check if you have the right drivers installed for the mouse that you are trying to use
May 29, 2009 | Acer Aspire One PC Notebook
Laptop is locked out
just learn to play it's fine
Oct 20, 2008 | IBM ThinkPad T21 Notebook
My sansa e250 it doesn't work
chech out for the lock key at he top at side of the earphone port.. it is lock key move it to unlock
May 09, 2008 | SanDisk Sansa e250 MP3 Player
Oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Mitac Mio 168 Pocket PC Logo
93 people viewed this question
Top Mitac Computers & Internet Experts
Alun Cox
iphone service
Are you a Mitac Computer and Internet Expert? Answer questions, earn points and help others
