HP 8150N ERROR CODE 79.060E
HP 8150N LASERJET. WITH XP 65 BIT OS
THE PRINTER STOPS AND DISPLAYS ON THE LCD DISPLAY 79.060E PRINTER ERROR. THE PRINTER HAS BEEN WORKING FINE FOR ABOUT 8 MONTHS BUT IT'S NOW STARTED DISPLAYING THIS WHEN PRINTING FROM ACAD 2006. IF ANYONE CAN HELP AS TO WHY ITS DISPLAYING THIS MESSAGE IT WOULD BE GREATLY APPRECIATED. THANKS
drunie
Power off the printer. Unplug the printer's USB cable for 5 seconds replug turn on the printer. If that fails power off the PC and printer unplug the USB cable at the PC and printer replug and power back on the PC. After PC is fully booted turn the printer back on. If this keeps reoccurring please replace the USB cable and or try different USB ports.
Posted on Aug 18, 2008
We have a HP 8150N. The printer will not print and is giving a 62.0 printer error message. We have turned the printer on and off which has not helped. Is there an eazy fix?
62.0 memory error. This error indicates that the memory that is soldered to the formatter is likely bad. If the error was 62.1 or 62.2 that would indicate that the memory in one of the upgrade slots was bad. The only real solution to 62.0 will be to replace the formatter.
Jun 13, 2011 | HP LaserJet 8150n Printer
Hp laserjet 8150 black blocks lcd display
If the printer isn't intializing then you may have a formatter issue. Try reseating the the formatter in the back of the printer. There is two thumb screws that hold it in place. If the printer is booting up and you can still print to it but you just can't read the control panel then the problem is with the control panel.
May 17, 2010 | HP LaserJet 8150n Printer
HP Laserjet 8150N User Error 50.1
The 50.1 error is caused by the fuser assembly not getting hot. The part you need is called a maintenance kit, it comes with the fuser and all of the pickup rollers needed to keep the printer in good shape. We have the kits available for $125 plus shipping. You can contact us at 318-447-9040 or at tech@ccl-la.com if you need to place an order. The kit will also include a PDF version of the service manual for this printer.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | HP LaserJet 8150n Printer
Printer Model : hp LaserJet 3020 OS : Windows XP(32 bit) Problem : When I did my last firmware update I interrupted by pressing the cancel button on my printer control panel as it showed "Printing...
Never ever touch the printer while upgrading the firmware.
You now need to replace the formatter
  • DO NOT power cycle the printer or the PC during this process or the printer may become unstable and or unusable without further attention from HP . The firmware update can take up to 5 minutes to complete. Please be patient.
  • During the printer firmware update, the liquid crystal display (LCD) on the printer control panel will display "Printing Document" and will change to "Erasing". After a short while, the LCD display will change to "Programming". After a short while, the LCD will display "complete : )" and the "Ready" LED on the printer will be flashing. The printer will automatically power cycle to reboot and will make noises similar to power on.
Jan 28, 2010 | HP LaserJet 3020 All-In-One Printer
Scanner reserved for pc scan
Get the latest driver´s for windows vista or get rid of windows vista it´s not a good OS extremely slow and very messy a lot of problems a resources consumption.
Hope it helps
Jun 25, 2009 | HP LaserJet 3030 All-In-One Printer
50.1 fuser error
Fuser error is the high voltage drum. Normally there is a blown fuse somewhere attached to it that gives the error other you could have a defective fuser unit. Dont attemt yourself it works with very high voltages +- 600V
May 12, 2009 | HP LaserJet 8150n Printer
Blank LCD display on Laserjet 3200
The LCD needs to be replaced. It is given an error code that you cant see.
Feb 11, 2009 | HP LaserJet 3200se Printer
Printer is displaying 65.12 error
There is no 65.xx error code
the following code should help you.
66.00.15 EXTERNAL DEVICE FAILURE
Description
The stacker or stapler/stacker was removed and then replaced with the printer power was on.
Action
1. Turn the printer power off.
2. Make sure that the accessory is properly seated on and connected to the printer, without any gaps between the printer and the accessory. If the accessory uses cables, disconnect and reconnect them.
3. Turn the printer power on.
4. If the error reappears, record the message, and contact HP Customer Support.
Oct 29, 2008 | HP LaserJet 4350 Printer
Computers & Internet Logo
1,855 people viewed this question
David Payne
David Payne
