PANASONIC DUCTLESS SPLIT
I HAVE A PANOSONIC DUCTLESS AC UNIT.THE INDOOR UNIT MODEL IS CS-C24BKP. THE OUTDOOR UNIT IS CU-C24BKP6. THE PROBLEM I AM HAVING IS THAT THE SET POINT IS NOT BEING ACHIEVED.NO ICE BUILDUP ON THE EVAP.THE UNIT WILL RUN CYCLE OFF AND THE 3TO 4MIN AFTER CYCLE BACK ON AGAIN.I SUSPECT IT IS THE BOARD OR THE RETURN AIR SENSOR.CAN SOMEONE HELP ME
  • majars Mar 22, 2008
    thanks i did troubleshoot correctly.the air inlet sensor was out of wack.you are also on the right track
  • 236 Answers
Try to check the resistance of your room air and coil thermistor may be its out of range the reading of both thermistor is 8000 to 10000 ohms @ 25deg C temperature. if its higher or lower then the thermistor is out of range and need replacement. And try also to check your terminals and connector for loose.
Posted on Mar 19, 2008
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
Panasonic mini split air conditioner css9nkua. what does run code h99 mean?
H99: Indoor heat exchanger anti-freezing protection
Causes: - Insufficient refrigerant;
- Air filter dirty;
- Clogged cross flow fan.
Apr 29, 2015 | Panasonic CS-S9NKUA Ductless Mini Split...
WHERE CAN I GET A PANASONIC REMOTE CONTROL NU,A75C3702 FOR MY AIR CONDITIONER RICK
Send a message to me on Facebook at Connectors Audio and Video Services page. Panasonic is a brand I carry and will do some calling for you. Please include the model number.
Oct 31, 2014 | Panasonic CU4KS24NBU 24,200 BTU...
I have a panasonic split system in the kids bedroom its an ECONAVI indoor unit is CS-E9NKR we have not used this A/C since last summer, now the compressor will not start, only the indoor unit operates
Typically on a mini split the outdoor unit is powered and the indoor unit gets its power from the outdoor unit. If the unit is a year old you might have lost your charge. Look at the connections at the indoor unit and outdoor unit. You will typically see oil or a dirty area on your copper were there is a leak.
Nov 16, 2013 | Panasonic Heating & Cooling
F95 error code - outdoor high pressure rise protection
This depends entirely on the environment you have your unit situated in. I would suggest getting a properly qualified and licensed technician to check your unit and see if it is working correctly in the environment you have it in. Maybe some adjustments for your climate are required.
Nov 10, 2013 | Panasonic CS-S12NKUA 12,000 BTU Low...
Troubleshoot whining Noise On Panasonic Outdoor Condenser
You will have to post a video to have any diagnostic performed sight unseen.
Aug 22, 2013 | Panasonic CS-S22NKU-1 21,000 BTU Ductless...
Panasonic cs-pw9gke i need wiring diagram
Split A/C-Cold:
You need four wires(two #10 and two #12) to the outdoor unit, leaving you house, and three wires(#10) coming from the breaker to tye indoor unit inside your house.
Split A/C-Cold and Hot:
You need five wires(two #10 and three #12) to the outdoor unit, leaving your house, and thee wires(#10) coming from the breaker to your indoor unit inside your house.
This ypical arrangment(all of them use three wires fro the breaker), yet there are other units which may require 6-7 wires connected to the the outdoor unit depends on the added features to the unit.
Regards,
Gulftecheng
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
162 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
