Question about Mitsubishi VS-50707 50" Rear Projection Television
Power turns off and color is off when first powered up
Power turns itself off intermittently. Sometimes you can turn it right back on and sometime it goes right back off and won't power up and stay on for a while. Also, color when first powered up, is off, separated. Green, red, blue stripes some places and lack of color others places.
Mine too turns off and on all the time. Sometimes it comes back on right away and sometimes it takes a while.I ran a code test and it comes up code 12. what could be the problem..
Posted on Sep 28, 2008
    President:
  • 4,402 Answers
Mitsubishi > VS XXXX
this model is famous for fluid leaks. each projector True True (``````````` (``````````` 0 95250 95250 power turns off and color is off when first powere - clip_image002.png tube has a reservoir on the front of it with a fluid in it. this keeps the face of the tube cool.
this depends on how bad the damage is in the tv. in most cases we can reseal the tube and clean up the fluid 400-600.
Once you
take the tube out you will see where it leaked. The problem is that the
frame on the CRT that the heavy screws with springs are mounted on (that
hold the lens coupled to the CRT) is weak and they can bend. We have seen
several that have leaked after the customer moved the set. You can only
tighten them down so much because the frame bends. It is just stamped metal
and not welded at the corners to support the bend.
We remove the CRT, clean it all up, add a very small amount of RTV sealer to
the gasket, reassemble, let the RTV cure thoroughly and refill with coolant.
The extra sealer should prevent future leaks. Haven't had a recall yet.
Mits says replace the CRT...too costly.
You msut check the yokes carefully as well. If any coolant gets into them
you can end up with shorts there and a mess.
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Apr 08, 2008
My SES Taurus will not start and shuts off by itself!
how to install software to gfive g111
mobile
May 19, 2012 | 2002 Ford Taurus
Power is intermittent. The unit will turn off by itself and then sometimes won't turn back on for a d ay and then it will. I have reseated the power cord, used another outlet; removed the case and checked...
I'm having the same problem with the power being on one minute and then there's just nothing there the next, can be out for hours and then just all of a sudden comes back on, have tried different power points etc, anyone got any ideas? bad wiring?
Ally
Dec 21, 2010 | LG RC797T
2003 Expedition turns off while driving and check engine light stays on? Will turn right back on but 5 minutes later will turn off again?
When you have the service light come on all the time is simply indicates that there are detected error codes by the car computer that requires an attention.
It does not necessarily mean that it is a problem that will make the car not to run but you will need to get a scantoool to enable you determine what the actual issue is.
Please scan the car.
Cheers.
Apr 16, 2010 | 2003 Ford Expedition
Display suddenly becomes pixelated or fuzzy
just goto mycomputer then right click select properties
display setting adjust the bit of the color make it 32 bit
or if your O.S vista just right click on the desktop click personaliza display setting. change the color into 32bit .
Mar 05, 2010 | Dell Vostro 1310 Notebook
Hitachi S57500 projection tv turns itself off
Hi, I`m afraid it`s not good news, you have a bad green picture tube, video-tek
Feb 10, 2009 | Hitachi 57S500 57" Rear Projection...
Laptop intermittently turns off
I think this the virus problem have youantivirus with you otherwise please download free avg and scan your system
Thanks
T.Boopathy
Sep 15, 2008 | Computers & Internet
Kirby G5 intermittent power
I would say that it is a short in the power cord.
Try my troubleshooting guide. It helps with do-it-yourself Kirby repairs. You'll also find links to directions, parts (cords too!!) and free repair guides!
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Jul 31, 2008 | Kirby G5 Bagged Upright Vacuum
Picture tube doesn't turn off
The power relay driver or the relay itself is bad. Its sticking closed so the voltage is there for the power supply but the micro has turned off the tuner.
Sep 15, 2006 | Panasonic CT-27G23 27" TV
Mitsubishi VS-50707 50" Rear Projection Television Logo
207 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
