Question about Philips 51PW9363 51" Rear Projection HDTV-Ready Television
51PW9303/17F Need a part number for a convergence board for this model? Can anyone help? and where i might order it from?
  • huskerboy51 Apr 08, 2008
    I would like info on fixing the board for half the price. Please let me know some details, email is huskerboy51@hotmail.com
  • Philips Master
  • 8,617 Answers
Its available at the following link its caklled the small signal board where the convergence is located. Its about 400.00 Have you considered rebuilding yours. I can post a link where you can get your board rebuilt for less than half of that. The link for the new board is .
http://www.partstore.com/Default.aspx
If you want a link to the site that will rebuild your board let me know.
Posted on Mar 19, 2008
Convergence chips and resistors
In order to assist further, more information is required. You indicate that there are some discolored resistors on the board. There should be a marking on the board at each location like: Rxxx Where the xxx is a number. If you can post the numbers here for the parts that are discolored, I can look them up in the service manual for you.
Thanks,
Dan
May 21, 2009 | Zenith R40W46 40" Rear Projection...
Samsung SP43J5HF Rear Projection Tv
Hi Daml
You can find this part from Samsung UK , click HERE to check it out and also to order it. Delivery is within 7 days.
Could unfortunately not find anything for Australia.
Let me know if you need any further assistance.
Thanks for using Fixya !
Apr 30, 2008 | Televison & Video
Samsung hcn4226wx/xaa red color out of focus
Ok first of all, the convergence board you are looking for is no longer available from Samsung, probably because of the large failure these boards are having. The only thing to do though would be to replace the convergence amp IC's on the convergence amp board. this will involve locating the convergence amp board, going to http://www.samsungparts.com, entering your model number, without the /xaa prefix. Locating the list of parts for this TV set, and getting the right convergence amp IC's for this TV set. The numbers for the convergence amps are STK-392-040. You will also need to get the service manual for this TV set to perform touchup convergence, as well as to realighn the magic focus into the memory of this TV set. If you have the ability to solder and unsolder, you should have no problem replacing thes convergence amp IC's. But i will have to say this, about 45% of these TV sets do still have a problem after the convergence IC's are replaced. this is usually due to the burnt ground return resustors on the convergence board, so be perpared to know how to read a scematic diagram in the service manual and to trouble shoot the board. There is no simple repair to this problem I'm afraid, with this Samsung TV set. But , if at any time, you feel lost in the repair of this set, do not continue, and call out a pro to assist you in the repair of this TV set. Good Luck with the repair of this TV set.
Jun 26, 2007 | Samsung HCN4226W 42" Rear Projection...
Need of a Convergence Board for an RCA PROSCAN Model 80690WW1
You can order a replacement Convergence Board or Convergence Amplifier Board for this model (PS8069) from a major RCA parts distributor at the link below:
RCA PS80690 Replacement Part Convergence Board
RCA PS80690 Replacement Part Convergence Amplifier Board (2F27039-502)
Please note, these boards are no longer available from the original manufacturer (RCA) and only appear to be available from PTS.
Apr 08, 2009 | RCA Televison & Video
Coloring is off and there is a ghosting effect
Part # BP95-00142E is the correct convergence amp board for a model # HCN4226W. Part # BP94-00155A is listed as a "CG Amp assembly board" also, but is not correct for a model # HCN4226W. They are both basically convergence amp boards. Here's a link to order the original Samsung covergence amp board for this model (HCN4226W) from a major parts distributor:
Samsung HCN4226W Replacement Part Convergence Amp Board
Jan 30, 2009 | Televison & Video
Rca r52wh77 help!!!!
to replace the power deflection board. i will need to know the family number this is a yx1 or yx38 or something like that that is found after model number..there are two model numbers on label this is a small number above the larger model number for instnance it can be r52wh77yx1... very important to get correct number.. these boards if you can get them range from 350 to 65 just depending on that number
Sep 09, 2008 | RCA R56WH76 Projection Television
Convergence Board
Have you tried just replacing the STKs? This set uses two STK392-120s I think.
Dan
Mar 18, 2008 | Philips 51PW9303 51" Rear Projection...
Convergence
Two boards govern this circuit . 1) convergence power supply board # 271860 2) convergence amplifer # 271861 . In most cases amp board is your problem . You might want to check the amp board for loose connections on it .Most of the times its the cable sockets on the borad have loose pins . This the board that has the metal heat sinks in a row of about nine of them on the board . Good luck
Mar 11, 2008 | RCA HD52W59 HDTV Projection Television
Convergence
Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link:
Feb 21, 2008 | RCA HD52W66 Projection Television
AUSTRALIAN PARTS
the convergence board has nothing to do with tuning of tv, the convergence board put three colour gun (red, green, blue) to work with each other, else you get three image, of red , green,  blue or mixture of all as seperate image, the convergence board for american tv and Australian tv is possibly the same what you check to see the board  part number is the same you possibly need to see if the convergence board has got the memory i.c. if that is the case, you need to tune you t.v reset the channel etc good luck.
need more help let me know.
Oct 09, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Philips 51PW9363 51" Rear Projection HDTV-Ready Television Logo
158 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
