Question about Baby Lock Ellure
Babyloc The needle seems to bunch up whatever I do to resolve it, such as pull out loose threads, re-insert bobbin, etc. It is a brand new machine that has barely been used, although I have had it for about two years.
Have you tryed to tighthen or lossen your thread tennsion? That may help. Good luck!
Posted on Mar 22, 2008
The bobbin thread is bunching up
hi Lois.
this is all i could find out.
Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimes thread bunching can be caused by something as simple as the tension dial being inadvertently turn.
or try this link.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
or this one,
Sewing Machine Thread Bunching Up Here Why .
if you go to this link a little window might open up in the middle of the page just close the little window down.
or this.
The bobbin thread is bunching up Google Search
Dec 12, 2017 | Sewing Machines
Needle in stuck position makes noise and thread on bottom is bunched up
Sounds like you have a ball of knotted thread wrapped up in the bobbin area and the needle is stuck in it. Whatever you do, do NOT yank on the fabric or thread! That could alter the needle/hook timing and require repair service. Be sure to raise the presser foot so the tension disk is released. Then remove the threads by clipping and gently pulling--practice patience. Sometimes, if you are able, removing the bobbin works will release the rats nest.
Once you get it unjammed, try installing a brand new needle before testing it again. And completely rethread the machine. (ALWAYS raise the presser foot when threading!)
How to Fix Thread Jam Sewing Machine
Discussions
If it continues to happen, try different types of thread and see if it works better with some than others. Avoid old thread (grandmother's sewing basket) or thread from bargain bins. There are a lot of better quality threads available that will work better with your machine, ie Mettler, Guttermann, Aurafil, Isacord, Sulky... Contrary to popular belief, Coats & Clark is not one of the better threads--it used to be. Sometimes, it takes some experimentation as some machines just seem to work better with a certain brand.
If still having problems, it could be a needle/hook timing problem. Take it for service.
May 25, 2016 | Sewing Machines
Cotton is loose/looping under material?
Sounds like bird nesting.
The #1 thing is to install a brand new needle (old, worn, nicked, or bent needles can create a lot of havoc).
Remove all the thread from the machine. RAISE the presser foot and rethread from the beginning verifying that it is threaded correctly. Make sure the bobbin is loaded and threaded in the bobbin case properly.
Why Do Get Bunched Up Thread Under My Fabric
8 Tips to Fix Birdnesting in Embroidery
Jan 28, 2016 | Sewing Machines
Still having with husquvarna designer I sewing machine. Tried new needles, changed stabilizer, tightened tension and loosed tension and still it is wrapping around needle plate and bunching underneath
Check bobbin case for loose threads in spring area that could be causing bobbin not to hold enough tension on bobbin thread. You can check bobbin case tension by using your needle plate. Holding bobbin case in your hand, insert a bobbin and thread it through the spring as usual. On the end of the bobbin thread, tie your needle plate to the thread. Hold case in your hand side ways so that thread travels downward with needle plate and thread trails downward across the case. The case should be perpendicular to the table top or floor. The weight of the needle plate should be so that the thread does not travel down unless the bobbin case is shaken slightly. The thread should then travel down slowly but stop once you hold case steady. If this is ok, check top tension. Turn on the machine. Lower the presser foot. With needle threaded, pull the thread the needle. You should feel some resistance. If there is none. Raise the presser foot and brush out any loose threads that might be caught in the upper tension disks. Many times, loose threads can get caught here that will keep disks from closing completely.
Hope this helps. Good luck.
Oct 30, 2014 | Husqvarna Designer I
I have the brother CE5500PRW sewing machine. I
Are you 100% sure you are using the right size bobbin?
Sep 11, 2017 | Sewing Machines
My machine is noisy seems stiff and the thread is bunching underneath bobbin case seems loose
It may need a cleaning and lubrication to resolve the noise and stiffness.
as to the thread bunching on the bottom, try re-threading both the top thread and the bottom thread, if it persists, try a different bobbin, (the one your using may not be wound properly, it happens) If it still persists try a new needle. if all of this fails, take the machine to a reputable service facility, it usually helps to take a sample stitching to show them exactly what it's doing to you,
Good luck and happy sewing!
Aug 12, 2014 | Sewing Machines
I bought a #7442 last Christmas and have not had a chance to use it until now. BRAND NEW, w/Carry Box and all. Anyway, my husband and I have spent ALL DAY trying to get it to work! We watched the DVD 5...
Not sure what brand of machine you have but generally after threading the bobbin the thread should be pulled out through a spring like device and by pulling on this thread and holding the bobbin case loosely in your hand, the bobbin case should turn clockwise inside the case. Clockwise is essential.
Then turn the machine by slowly by hand and let the needle go down and up once. Then pull up the end of the needle thread which should then lift the bobbin thread with it. Pull both through the back of the presser foot and start to sew. I hope.
Dec 08, 2010 | Sewing Machines
I have a Singer mod 9134 sewing machine. It keeps
Try inserting the bobbin in the reverse direction. Most machines take a bobbin clockwise or counterclockwise and it can make a difference. Also try a new needle, a bad needle is often the problem believe it or not.
Nov 10, 2009 | Sewing Machines
Babylock sewing machine, upper thread is bunching
the tension is wronge has the lower bobbin case been unwound and refilled)(check that this is threaded right as well)
Sep 05, 2009 | Sewing Machines
Needle won't move; something stuck/dislodged
Can you remove the bobbin? Sometimes when thread gets bunched up under the lower plate it will force the bobbin out of position. Try taking it out and cleaning any loose thread and lint from the area. Put a couple of drops of oil on the outside of the bobbin case and re-insert it. Make sure you lower the needle and pull the bobbin thread through to the top and back behind the needle before beginning to sew again.
Hope this works!
Zelma
Jan 18, 2008 | Brother XL-2230 Mechanical Sewing Machine
Sewing Machines Logo
35 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
