FixYa.com
Tags:
Ricoh Aficio 1013F Copier
Ricoh Aficio 1018 photocopier (by 2 users)
posted by caveat on Mar 18, 2008
I have a functional problem come up on the display and the code used is "SC320" can you tell me what this code is for, because the book doesn't tell me. The photocopier is Ricoh Aficio 1018
RICOH Aficio 1013F Display shows "Functional problems" code SC551 Power switched off and on again, no result. The glass **** window is clean. The machine does not appear to be overheating. Can you please suggest a cure ?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on May 14, 2008
sc922
Best Solution
posted on Mar 19, 2008
Helpful (85)
bowdo
Rank:Guru Guru
Rating: 89%, 85 votes
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Copiers problems?
Copiers
minolta
minolta ep 1030 copier paper... Answer This...
Copiers
cf323
same probelem Answer This...
Copiers
Nuvera 100 CP
I have a Xerox Nuvera 100 that... Answer This...
Copiers
toner drum chip reset for xerox...
Sir, I am Ekambaram from India.... Answer This...
Konica 1216 copier makes black...
I bought a preowned copier... Answer This...
Repair Service
Find Copier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
