I have a front load washer. When I push the start it makes a humming noise but no water enters the washer. HELP
  • 1,314 Answers
Either your not getting any water from the water faucets turn them off remove the hoses from the back of the machines and make sure the screens are clear on the water valves then get a bucket and stick the hoses in the bucket and turn them on to make sure the valves are working if all that's good replace the washer valves low water pressure can cause this also
Posted on Mar 18, 2008
2 Suggested Answers
SOURCE: Washer will not start a cycle just makes a humming
Does it have a reset button
Posted on Jul 19, 2009
My whirlpool cabriolet will not start a load or add any water at all. It just makes a humming noise
Are your water lines turned on? If so The humming noise you hear is the solenoid that allows water to enter unit. If that solenoid is stuck no water will enter but you will hear the humming noise.
Nov 13, 2015 | Whirlpool Washing Machines
How do I fix the washer if it makes a humming noise when I start it but no water comes out and fills up?
Make sure that the water valves are turned on and that the hoses are not kinked.
Is the symptom the same for all temperature settings?
Feb 03, 2011 | Kenmore 94702 Front Load Stacked Washer /...
The wash cycle clicks on and a small amount of water enters the drum, as normal, but then there is just a humming noise and the drum does not move. When I put it on the rinse and spin cycle (there is...
I removed the bottom panel under the door and drained the the tub. There is a white filter housing that unscrews, but you need to have towels handy to catch the water that comes out. The machine appeared to work after that but it would'nt drain and it turns out that the humming noise was coming from the drain pump connected to the filter. I ordered a new drain pump assembly, which should be easy to replace since it is located at the front of the washing machine.
Jan 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Moved to new home hooked everything up washer will not fill
ther's something wrong with your water supply to the washer the humming noise is the solenoid on water valve working check water taps to make sure there is water there and hoses are not kinked
Jun 24, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Lid switch is broke and need to replace.
1. Unplug machine
2. Remove two screws in back of angled top part connecting it to base, lift back up 4-6" and shift top toward front 1/2" so tabs holding front of top to machine base can disconnect.
Mar 27, 2009 | Kenmore 24622 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Lg washer 2277, spin cycle
The humming noise is probably the drain pump working to remove the water out of the tub.  It is normal.
Apr 26, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
