Question about GE (PSS26MSRSS) Side by Side Refrigerator
Poor cooling on frezer and almost no cooling on refrigirator
GE - TFX22KHE - side by side refrigerator/freezer
Poor cooling on the freezer side. it is cool like the refrigerator, and almost no cooling at all on the refrigerator side.
The fan is working, I have vacuumed the condenser coils off of dust but no improvement.
    New Friend:
    Problem Solver:
  • 11 Answers
Water running in refrigerator means u have a drain problem remove the fan section you should see a drain in the bottom use pressurize air to clear the drain. Refrigerator not cooling, check if evaporator coil is a block of ice if it do u have a defrost problem, turn timer clockwise to manually put in defrost, if the unit goes in to defrost change the timer if not check your heater for resistance if no resistance is present change the heater if resistance is present let your defrost thermostat remain in the ice coil and check for resistance, if no resistance is present change the defrost thermostat, to check compressor section make sure thermostat is close and the unit is not in to defrost, make sure condenser is clean, condenser and compressor fan should run at the same time if only compressor runs check voltage to your fan if voltage is present change the fan, if only the fan runs check starting components, if breaker trip check for ground winding, if compressor is running, condenser fan is running, evaporator fan is running and your coil is partially frost you should installed your gauge, it could be that the system is low on charge are a restriction are a no good compressor, strachanmichael@yahoo.com Lincoln tech former student
Posted on Jan 17, 2013
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
SOURCE:
There is problem with our kenmore refrigirator the freezer is working but the refrigirator is not working. the refrigirator is not cold enogh it is going to 60 degree
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Kenmore Refrigerators
What is the ideal temp setting in GE side by side refrigirator. I have Freezer (0-9) Refrigirator (0-9) There was ice on the Freezer wall and the service guy replaced the defrost thermostat recently
If replacing the defrost thermostat fixed the icing problem that doesn't indicate your settings are wrong. But the desired temp in the freezer is from 0 to 10 degrees and in the fridge around 35 degrees.The actual number on your dial depends on the personal use. Use a thermometer to check it and allow 24 hours after changing it to check it.
May 25, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigirator constantly changes temprature
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Oct 25, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
My ge refrigirator is getting warm on refrigirator side but freezer side is doing fuine. model #csh25jftaabb send answer to
heatman101
Oct 02, 2010 | GE GSH25JFT
Refrigirator does not cool and bottom freezer works fine.
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling<br /><br />Refrigerator not Cooling or Fridge not Cooling<br /><a href="http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not" target="_blank">http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not</a><br /><br />How to Defrost Refrigerator Defrost Timer Problem <br /><a href="http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer" target="_blank">http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer</a><br /><br /><br />Water Running in efrigerator from Freezer<br /><a href="http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from" target="_blank">http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from</a><br /><br />heatman101</span><br />
Aug 26, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
The frezer not cool enoug
you may not have enough air circulation at the rear of the machine when you moved it. if the machine can not loose heat through the radiator at the back it looses its cooling capacity. move it back to where it was?
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frezer temp is 20 deg. fridge temp is 47 deg.
Remove the freezer shelves and bins. Remove the freezer back panel to access the fan motor.
May 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Model # GSS20IEPA WW Fridge warm...freezer is fine
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 28, 2009 | GE GSS20IEP Side by Side Refrigerator
Freezer problem
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Oct 23, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,654 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
