Are you sure that there is not a buton on it that says degrees Celcuis of Farenheit. It happened to me a few years ago. If there is such a button try pushing it to see if it will go back to normal.
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
I have the same problem on my AOCS3040 oven....door will not shut tightly so it loses heat and is about 25 degrees off plus the escaped heat makes the control panel get very hot during cooking.
that was your element burning out. you can change it from inside the oven but be carefull not to lose the wires. if you do you have to take the oven out to reconnect them
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
Remove cover at rear of oven compartment, there you will see the element.
Undo fixing screw(s), carefully pull the element towards you, remove wires, be careful not to lose them inside ,and fit onto new element.
Refit element and rear cover.
Plz rate my solution.
Thanks.
