Question about HP Pavilion a1220n (A1220NED904AA) PC Desktop
My desktop shut down and is asking me to re install a 32 windows file. What is this and how do I fix it?
    New Friend:
    Problem Solver:
  • 8 Answers
Open up cmd write in sfc/scannow
i prefer that before you reinstall the entire Windows
Posted on Apr 11, 2010
    Scholar:
  • 62 Answers
Hi ,
In simple words this is a windows file which helps the computer to boot up to the desktop .This file can be reinstalled only by runing a recovery that takes the computer back to its original factory settings.But there are steps that can repair the file ......
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
If u dont have the windows cd then u can boot the computer to the system recovery page by tapping the f10 key repeatedly when the computer boots up then when u get to the recovery page hold on to the ALT key on the keyboard and then press D.The recovery console page opens up then type in the command chkdsk then a space followed by a forward slash then press r.....the repair will start then the computer will restart and hope it takes care of the issue.
OR
When the computer boots up tapp the f8 key repeatedly then u will get to the advance boot menu page then select safe mode and then hit enter .Select recovery console and then enter ,once the command prompt page opens tyoe chkdsk space forward slash r.......should repair the file and get u back to the desktop ....
If non of the options work you would have to run a recovery
ALL THE BEST
Posted on Apr 10, 2010
    New Friend:
  • 36 Answers
Your windows is corrupted, I recommend to re-install windows(backup your files first using a USB drive and scan them with your antivirus before you put them back). Since is a HP, click on start and type "recovery" select the option that allows you to go a factory default. You may have to select NO to options before you get to factory default set. The process could take a couple hours depending in your machine. Alternatives solutions will be like "repair windows" that actually never work. This recovery option is located in the partition of your hard drive sometimes shown as drive 'D"
  • 103 Answers
Hi, This normally means that a windows file from the system32 folder is missing or corrupt. You will have repair that by using your operating system cd and go to repair when prompted. If this does not work you may have to install a clean copy of your operating system.
SOURCE:
Inf file txtsetup sif corrupt or missing status 256
64-bit central processing unit is one that can support a higher amount of system resources than a 32-bit counterpart.
It has the ability to both recognize and use more amounts of available system memory to go along with its faster processing speeds.
If you want to install a 32-bit operating system on a computer with a 64-bit processor, you can--but you won't be taking full advantage of what your system has to offer you.
Place the installation disc for your 32-bit operating system in your computer's disc drive.
This can be one that you've purchased, as in the case of Microsoft's Windows operating system, or one that you've downloaded from the Internet, in the case of the Linux operating system.
Shut down your computer. Once completely off, turn it back on again.
Click "Next" to continue through your 32-bit operating system's setup program.
You will be asked to read the "TOS," or terms of service.
This is important legal information that you should read in detail, as it informs you of exactly what you're agreeing to by installing this operating system.
Specify any settings changes you want to make to the way your operating system is installed.
From these screens you can also input personal information into your operating system, such as your name or business information, which will save you the trouble of having to do it later when you install utilities.
Click "Install." The 32-bit operating system's setup program will format your hard drive, erasing all data on it.
It will then place the necessary operating system files on your computer.
This can take an hour or more depending on the operating system being used.
Once this process is finished, allow your computer to automatically restart.
http://zone.ni.com/devzone/cda/tut/p/id/5709
Sep 12, 2013 | Computers & Internet
Fix BIOS on Dell Inspiron 531 Vista Home Basic 32-bit
The BIOS may require flashing when an update is available or when replacing the system board.
  1. Turn on the computer.
  2. Locate the BIOS update file for your computer at the Dell Support website at support.dell.com.
  3. Click Download Now to download the file.
  4. If the Export Compliance Disclaimer window appears, click Yes, I Accept this Agreement.
The File Download window appears.
  1. Click Save this program to disk, and then click OK.
The Save In window appears.
  1. Click the down arrow to view the Save In menu, select Desktop, and then click Save.
The file downloads to your desktop.
  1. Click Close when the Download Complete window appears.
The file icon appears on your desktop and is titled the same as the downloaded BIOS update file.
  1. Double-click the file icon on the desktop and follow the on-screen instructions.
Aug 14, 2012 | Dell Inspiron 531s Desktop Computer
Have a new Windows 7. Adobe keeps asking to
I would recommend uninstalling the version of Adobe Reader you have installed through the Control Panel>Programs and Features.
Then download and install the latest version directly from Adobe's site.
http://get.adobe.com/reader/otherversions/
Jul 08, 2010 | Dell Dimension 2400 PC Desktop
Can i convert a 32 bit to a 64 bit
You can use the Upgrade option during Windows 7 installation, which preserves your files, settings, and programs, only if you're currently running a 32-bit version of Windows Vista and you want to upgrade to the 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only perform an upgrade to a 64-bit version of Windows 7. For more information, go to Upgrading to Windows 7: frequently asked questions on the Windows website.
If you want to move from a 32-bit version of Windows to a 64-bit version of Windows 7 or vice versa, you'll need to back up your files and choose the Custom option during Windows 7 installation. Then, you'll need to restore your files and reinstall your programs. For more information about performing a custom installation, see Installing and reinstalling Windows 7‍.
gl_ico.png Notes
  • To install a 64-bit version of Windows 7 on a computer running a 32-bit version of Windows, you'll need to start, or boot, your computer using a 64-bit Windows 7 installation disc or files.
  • If you start your computer using a 64-bit Windows 7 installation disc or files, but your computer isn't capable of running a 64-bit version of Windows, you'll see a Windows Boot Manager error. You'll need to use a 32-bit Windows 7 installation disc or files instead.
  • Windows Easy Transfer can't transfer files from a 64-bit version of Windows to a 32-bit version of Windows. If you're running a 64-bit version of Windows Vista but you plan to install a 32-bit version of Windows 7, you can move your files to an external location manually or use Backup and Restore in Windows Vista. For more information, go to Back up your files and
Apr 08, 2010 | Dell Precision Workstation 490 - MT -...
Ihave a ga-ep45-ds3r and when I shut down properly and then turn back on I get an improper shut down notice, a blue screen message and then it attempts to restart. It will time out and default to normal...
there is a log file in ur c drive which accidently or by antivirus has converted the file into an archieve file, plz find the boot.ini file in ur c drive or in system 32 folder.
Jun 20, 2009 | Computers & Internet
My desktop cannot shut down? After i install game that i download.
Try removing the game driver from the system then see if the problem is fixed. If this fixes the problem, make sure you have the correct drivers for VISTA. Most Vista platforms are 64 bit and if you are using a 32 bit driver that will cause the problem. Check for an updated game driver from the company that makes your driver. If they have had issues with VISTA and who hasn't they may just have a new driver for you. Good Luck with VISTA!
Jun 02, 2009 | Microsoft Windows Vista Home Premium with...
Acer aspire 5920 laptop is not shutting down.
Try to shut down it trough it frm shortcuts keys given on laptop or you can even re-install windows (if u hav no important data in tht laptop).
May 07, 2009 | Acer Aspire 5920 Notebook PC
Windows 32 file is missing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0mm 5.4pt 0mm 5.4pt; mso-para-margin:0mm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Windows 32 file is a system file this one along with others if faulty or corrupted will stop windows working
The easiest way in the long term is to.
Boot from Windows CD and after all files are loaded. Windows will ask you what you want to do. Install, Repair etc. Choose repair and follow instruction from there Windows will remove some files and reinstall in repair mode. You will not lose any files, during this process.
The reason I choose this method is because you can spend some hours trying to fix not starting problems and not succeed while a reboot in repair mode takes ¾ of an hour plus time to load drivers
Oct 17, 2008 | Intel D845GVSR Motherboard
System restore
your system 32 files are corrupted, you hav to either install another windows or repair the infected part of the files...
Oct 11, 2008 | E-Machines eMachines Desktop PC
HP Pavilion a1220n (A1220NED904AA) PC Desktop Logo
237 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
