Question about Maytag PAV2300 Top Load Washer
Washer wont run but is trying to
When i start the washer it makes a humming sound, and smells like electrical burning. If I spin the tub a few times it will start, but when the next cycle is supposed to start it will do the same thing. I then have to turn the tub to get it to do each cycle.
    Master:
  • 788 Answers
Something is probably binding. Check the belts and bearings underneath or by removing the back if possible. There could be something stuck around the rim of the tub. Does it work fine when it's empty? Could also be that the motor is getting near the end of it's life. The motor should not be too hard to replace and it shouldn't cost too much.
Good Luck!
Posted on Mar 18, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
I think it is your motor that is the problem.. It must be the coils inside the motor that have got affected and that is why the noises and the turning prob... Tell a technician to come and remove the motor and get it repaired or get a new motor....
  • 871 Answers
Check the motor for that, there may be smoething stuck ther. for the humming sound, when did this started happening? for the smell, check for frounded wire. for repeating each cycle, try to check for the housing if its still operational because the burnt smell and the cycle repeating is linked.
My whirlpool ultimate careII quiet wash washer stopped working in mid cycle. It won't agitate, drain, spin, fill with water, nothing. The washer makes a humming sound and an electrical burning smell.
If your smelling electrical burn.. It's most likely to be the motor is bad.. Or just stuck, new washers made today are DC motors and contain a circuit board in the motor.. And are not serviceable.. Just replace them..
Dec 02, 2016 | Whirlpool Washing Machines
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Top load frigidaire washer will not spin, it agitates, it drains
You need to replace the starter cap on the motor this is why it will not turn and the smell is the cap that's not starting the motor it also will hum.
Dec 29, 2013 | Frigidaire FFLE2022MW Electric...
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Seized tub - Maytag pavt244aww washer
you may have a seized up pulley on your pump. this will burn the belt. also check the pulley on the end of the motor.
Oct 27, 2009 | Washing Machines
Kenmore direct drive washer - not spinning
While it could be the tranmission, that is a fairly rugged part (although not impossible). More often, you have bad contacts in your timer. These will short together and cause the machine to try and do multiple things at once, thus causing the burning smell. You didn't list a model number, but for most of the Kenmore washers, you can open the console (two phiilips screws on the front or back towards the bottom) to access the timer. Most timers are able to be opened to verify visably black or silver marks on the normally brass colored contacts.
Jun 18, 2008 | Kenmore 24032\24036 Top Load Washer
Sounds like the motor or capacitor (next to the motor), the capacitor helps the motor to start, once running a switch inside the motor disconnects the capacitor from circuit.
Mar 18, 2008 | Maytag PAV2300 Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Maytag PAV2300 Top Load Washer Logo
102 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
