Question about RCA R52WM24 52" HDTV Projection Television
R52wh74 Convergence My TV has the same 3D effect. There is no Convergence on the menu now. Are the IC Semi conductors a common probem. If so where are they located and do they have to be sodered on
  • 3 more comments
  • tinawooley Mar 28, 2008
    My RCA R52WM24 TV has the same problem. We have replaced the fusible link fl231 and we still have no luck. Has your TV been fixed? Any advice on how to fix mine? Thanks!!
  • Erik Pouch Sep 22, 2008
    Yup. Same model, same problem. Where on earth can I find the service manual and parts?
  • Anonymous Mar 31, 2009
    fUUUUUUUUUUUUUUUUUCKKKKKKK THISSSSSSSSSSSSS
    $1000 after 1 year is rendered useless
  • clondon56 Apr 02, 2009
    i am getting the 3 d effect also
  • nohavecd May 11, 2010
    I am having a similar color separation (3D effect) problem with my RCA R52WH74 tv. I have replaced the FL231 fuse, and it fixed the problem for a few days, but the fuse then went out again. I hesitate to just keep replacing the fuse, as there is some other root cause for the problem.
    The DL231 diode was fine when I checked it.
    Is there anything else I could check on the convergence board?
    Also - is there a way I could get ahold of the service manual?
    Thanks,
    Don
  • RCA Master
  • 8,617 Answers
If the convergence option is not on the menu anylonger. thats another issue all together. That is usually a fusible link and capacitor on the deflection board that will cause that to happen. The convergence ICs will also need replacing as the link and capacitor will most certainly take out the convergence ICs as well. You will need a service manual on this issue. Let me know and I will post a link where you can get one along with some free support to help you with it.
Posted on Mar 18, 2008
  • Sonny Berry
    Sonny Berry Mar 21, 2008
    yes the ICs are a common problem in all brands of bigscreen televisions. They are located on the largest heat sink on the chassis. However your problem lies deeper than the ICs as the conversion option has gone from your menu thats a sure sign that a fusible link and or capacitor is also at fault on the deflection panel as well as the ICs. This set will need to be checked over to locate the failed components on the deflection circuit before replacing the ICs . Failure to do so can and will destroy the new ICs. To do the repair yourself you will need the service manual. Most shops will insist you change the deflection panel and convergence ICs so I would guess youre looking at about 450.00 to have a repair shop do it.
I see rainbow on my color screen tv rca model r52wh74 color issues.
The problem of your tv is the convergence try to adjust it manually in the setting of your tv. If still same or no effect the convergence IC is already defective. You can find it inside your tv it is connected to a large aluminum called the heat sink it has a marking of stk- followed with a number.Try to replace it.
Jun 07, 2011 | RCA R52WH73 Projection Television
60pp9753/17 replaced convergence ic chips power light comes on blinks once but no picture or sound. checked power supply slight humming noise coming from the ssb area small red light on the circuit board...
Soldering or bad IC chips...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 15, 2011 | Philips 60PP9753 60" Rear Projection...
I am having a problem with convergence. I cannot manually make it work. Is this a sign of a bigger problem.
This is a very common probem on all projection TV sets. Not just sony. Your convergence IC chips and related parts have failed due to normal wear and tear. One common symptom when this occurs is your TV will look 3D and convergence won't adjust correctly. A repair shop will charge around 250 - 400 for the fix. Or you can get the parts and do it yourself. You can get complete parts and instructions from sites like www.TvRepairKits.com or if you know how to do these repairs you can gogole the parts and forgo the instructions.
Hope this helps a bit,
Dec 15, 2010 | Sony KP-53V75 53" Rear Projection...
3D effect where the blue color is a little lower than the rest of the colors. More noticeable on words.
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 20, 2010 | Philips 51PW9363 51" Rear Projection...
3d effect on left side of screen
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Apr 05, 2010 | Sony KP-51WS510 51" Rear Projection...
RCA projection tv R52WH74
quick question do you have the convergence option in the customer setup menu. if you do not then goto the tips and tricks section and read the fl231 fuse problem
Apr 23, 2009 | RCA HD52W58 52" TV
Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Mar 09, 2009 | RCA R52WH73 Projection Television
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
3D TV Blues, Greens, Red and a little yellow. RCA Modle # R52WH74
This is called convergence board failure. try to re calibrate the convergence. if the re calibration fails, this means your convergence board will need to be replaced or, rebuilt.
Feb 13, 2009 | RCA R52WH73 Projection Television
Rca r52wh74 projection 52" tv
Convergence in this unit can be one of 3 possible boards. can you adjust any ...do the crosshairs move in customer setup convergence menu
Jan 04, 2008 | RCA HD52W58 52" TV
RCA R52WM24 52" HDTV Projection Television Logo
1,689 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
